Problem Loading Custom Tune with My SCT X3 Tuner - Please Help
Alright, I finally got my tune from Tillmanspeed and now I can't load the damn thing on to my tuner.
If anyone out there has run into this problem I'd love to hear how you fixed it.
From what I've read I have to update the firmware on my tuner, but I can't seem to figure it out.
I've followed all of the instructions on the SCT website, watched the videos and it still gives me the error "Failed to write bulk data"
If I go straight to the "Load Custom Tune" box and click it, it then gives me the error "Failed to read data" a bunch of times, then it says "Not a Valid SCT Device".
This is really making me mad. I've searched forums and this has happened to SEVERAL people, same problem, and it seems to all come down to updating the firmware.
Any ideas?
Any ideas?
My problem is getting the new tune (via email) onto my tuner from my computer. When I plug the tuner into my computer, basically I just can't access the tuner from the computer in order to get my new tune loaded onto the tuner.
I did a search on some of the errors that people are having and there are lots of people having the same issues. It's not that the tuners or the software are faulty, it's just that the software sucks and should be much more user friendly. You should be able to open the program, plug your tuner in and go to work. Instead, in some cases, you have to hold down the "cancel" button on the tuner before you plug it in and while you're plugging it in or it won't be recognized properly by your computer. I mean, come on now, with as much as those tuners cost, they should all be running a much more sophisticated version of software.
What operating system? USB Driver needs to be updated so that the PC can communicate with the device. First time you plugged in the device, you should've seen a Found New Hardware Wizard, but if that doesnt show up when you plug the thing in it not the end of the world. Open up your Device Manager, find your SCT device in the list. If it has a yellow mark on it, then right-click on it and update the driver.
As I recall, I had to do this too.
One thing I can say to all who get one of these tuners (SCT X3) is this... MAKE SURE YOU LOAD THE SOFTWARE BEFORE YOU PLUG THE DEVICE INTO YOUR COMPUTER. I think that's where I may have gone wrong with the attempts on my laptop. I plugged it in not knowing that I needed software loaded first. If you do plug it in before you have the software loaded, then you will have to manually load your drivers. In my case, I couldn't manually load the drivers on my laptop because in the device manager it never showed up. Who knows..... So, in short, if you get one of these tuners, make sure you go to the SCT website (www.sctflash.com) and download the software.
So, it all worked out in the end. Thanks for all of the help!
