Hammer's Aluminator Project
#103
well total cost the way i did it, is shown in the parts list of the writeup. it's going
to vary a little depending on where you get your parts and whether you go with
ARP hardware or OEM TTY hardware.
basically it's a good chunk of change.....
#104
good job but i got a question, is the short block you use the same short block that also comes with the 4v heads, if so could you have purchased the shork block with the 4v heads and used it in your year mustang, would there be an advantage or disadvantage to using the 4v heads.
You would also have to change out the wiring harness and computer since the 4v uses a different PCM and wiring harness.
I ahve seen it done. However, if you are wanting to make big power, the 3v heads flow just a smidge under the 4v heads and actually make more under the same boost with certain blowers.
If you put a good set of cams on the stock heads, or ported your heads or pruchased a new set of ported heads, you would make a huge amount of power.
#107
http://home.comcast.net/~cookpaging/...ild/parts.html]
Seems strange in the grand scheme of things that a new shortblock is cheaper than a supercharger. Or...guess I should say it seems strange that a supercharger is more expensive than a short block.
#108
#109
not to worry, shane dug it up....guess i didn't hide it well enough lol.
i hear ya, but superchargers are nice and shiny and produce more smiles than boring, old blocks of aluminum.
