FRPP Top end package
#43
I replaced my 05 V6 with an 05 GT. It's actually the one pictured but the indicator on the left column still shows V6. The grille on it was from the previous owner... need to find a set of OEM lights for the grille I plan to get.
#45
I want to put a metal billet grille on with hidden lights. I am not a huge fan of the honeycomb. I like the bars. That's what I had on my v6. Do you still have your old grille stealth? I need lights lol.
#46
Sure this will make over 400hp on an engine dyno which is what they don't tell you. Take off like 15% and that's more like what you'll see after all of your parasitic loss. For example, in mm&ff they got 359.9hp and 352.1tq out of a "seasoned stock 3v.". The final numbers were 365.3tq and 431.6hp after adding the manifold, hot rod cams, and stage 3 heads. In the pictures, the engine has long tubes as well. Good luck getting those numbers to the wheels or even to the crank.
#47
I think livernois had one that made 380 whp NA out of their kit.. It's not a bad option if someone didn't want to go FI. Plus you don't have that extra 150 lbs. on the front of the car lol
I think the V3 and air to air, plus piping and all the hoses and bypass valves add about 100 lbs. to my car.
A dude on youtube ran 11.1@121mph NA on a similar NA set up...
mungodrums
10-07-2015 04:01 AM
mungodrums
Suspension
09-07-2015 07:28 PM
