Dyno tune vs brenspeed
Old 07-21-2010, 11:47 PM
"The S"
"The S"'s Avatar
Default Dyno tune vs brenspeed
Alright I have a C&L race intake, Steeda Delete plates, Detroit Rocker cams, LT's, and an o/r x pipe. Any reason to spend the money on a dyno tune Vs the Brenspeed one they sent me?
"The S" is offline
Old 07-22-2010, 06:57 AM
Nuke
Nuke's Avatar
Only if about an extra 5 or so RWHP is that meaningful to you, and that's assuming your current custom tune is pretty close. If you have a canned tune (you didn't mention who's tune you have), then even the Brenspeed tune would be a bigger bang. Most often, Brenspeed and AM tunes are pretty darn close to a dyno tune. But if you hit the track, those few extra ponies are worth it.
Nuke is offline
Old 07-22-2010, 09:12 AM
"The S"
"The S"'s Avatar
yup its a brenspeed tune.
"The S" is offline
Old 07-22-2010, 11:11 AM
joutcelt
joutcelt's Avatar
what gear do u have with that setup. generally speaking u will want 373 or 410
joutcelt is offline
Old 07-22-2010, 01:19 PM
jdmcbride
jdmcbride's Avatar
Did you purchase everything from Brenspeed? Or did you already have some things installed from another vendor?
jdmcbride is offline
Old 07-22-2010, 05:44 PM
"The S"
"The S"'s Avatar
purchased from them
"The S" is offline
Old 07-22-2010, 06:52 PM
T.Wayne
T.Wayne's Avatar
Default Not your standard cam
First things first you have a custom grind cam from Brenspeed and the tune from Brenspeed I have the same cams and tune for my 2006GT 5speed.
I have had 0 issues I would not allow someone else to tune this set up just because it's a custom grind. If I bought say Blow By Blow racing custom grind I would stick with the tune they provided or have them do the dyno.
Now you live in Flordia home to SCT and Steeda if your set on this idea this is a good starting point or drive to the Mid West and have Brenspeed do it.
It's not a off the shelf cam and I would seek Brenspeeds opinion on this to be on the safe side not to say no one else can't tune this cam profile I would be on the safe side and make a call. They may have a option for U that will be closer to home.
TW
T.Wayne is offline
Sixx
10-05-2015 07:36 PM
Explosive
10-02-2015 07:45 AM
uedlose
The Racers Bench
10-01-2015 08:31 PM
Florida Regional Chapter
09-30-2015 08:04 PM
RCS02v6
09-29-2015 01:46 PM
Quick Reply: Dyno tune vs brenspeed
