2nd gear grinding?
Old 08-02-2010, 07:43 PM
sweetlou69
sweetlou69's Avatar
Default 2nd gear grinding?
about 6 months ago i replaced my clutch and flywheel. I have the triax shifter, and just the past couple days going from 1st to 2nd it grinds alittle bit while shifting. But if i go from third down to second or start off in 2nd there are NO issues at all. Any ideas what could be causing this? Something not aligned right or became loose?
sweetlou69 is offline
Old 08-03-2010, 09:41 PM
BruceH
BruceH's Avatar
Is it hard to get into 1st or reverse from a stop?
BruceH is offline
Old 08-04-2010, 09:12 AM
sweetlou69
sweetlou69's Avatar
actually awhile back reverse was hard to get in there so i tightened the shifter bolts. This second gear this is a new issue.
Old 08-04-2010, 03:32 PM
sactown
sactown's Avatar
Which clutch and flywheel did you get?
sactown is offline
Old 08-04-2010, 04:35 PM
sweetlou69
sweetlou69's Avatar
spec stage 2/ aluminum fly wheel
Old 08-06-2010, 03:23 PM
sactown
sactown's Avatar
That is your issue, I was running the exact same setup and had nothing but problems with it. Very hard to get into gear, sometimes the car would start to move with the clutch pushed to the floor. That spec's setup is junk. don't waste your time with trying to fix it, it is not fixable.
sactown is offline
Old 08-13-2010, 04:19 PM
sweetlou69
sweetlou69's Avatar
ah ****ty really? it was fine for the first few months, its just of late. its a pain tho
Old 08-14-2010, 01:13 PM
drewsky
drewsky's Avatar
Im not exactly sure but I dont think the new stangs have an alluminum flywheel. If they dont I would not change it.. ill have to check...
drewsky is offline
Bokeo
10-10-2015 08:28 PM
KingRando
10-02-2015 08:06 AM
uedlose
The Racers Bench
10-01-2015 08:31 PM
junior04
09-28-2015 10:53 AM
Quick Reply: 2nd gear grinding?
