Manual transmission fluid change ?
Old 08-07-2010, 05:20 PM
dodger5
dodger5's Avatar
Exclamation Manual transmission fluid change ?
My 06 gt is at 62,000 miles and i think it now needs a transmission fluid change in the car from what i read, but i dont know how much it is going to be? Any info would be very helpful..... i plan to take it to GTR in Rancho to do it if they do.
20 views and no help come on now
dodger5 is offline
Old 08-08-2010, 05:40 AM
Goldenpony
Goldenpony's Avatar
Not sure what you are asking.
Goldenpony is offline
Old 08-08-2010, 09:06 AM
Unleashedbeast
Unleashedbeast's Avatar
it requires 3.2 quarts to fill to the bottom of the fill hole. Honestly, the manual is easy to do, and if you have the ability....do it yourself. If you have someone do it for you I would expect to pay for the fluid plus labor, but I'm guessing on these numbers.
4 quarts of GOOD fluid ~35.00-40.00
Labor - ~25.00-35.00
If it were MY transmission I would want no less than AMSOIL Universal Synthetic or Red Line D4. Those are the best two transmission fluids for the T3650 IMO. I currently have AMSOIL in mine, and the shifts are much smoother.
Unleashedbeast is offline
Old 08-08-2010, 03:01 PM
algregory
algregory's Avatar
I use Synthetic ATF, book calls for ATF. I think it also calls for a 30k interval. Fellow that says it is easy is correct. Even easier because Ford made the drain and fill plugs with a hole for 3/8" drive ratchet. The drain is on the bottom, the fill is on the passenger side. Parts Houses sell fluid and pumps. You just need to get it high enough off the ground to work. Then drain and fill until the fluid starts coming out of the hole.
algregory is offline
Old 08-08-2010, 04:28 PM
Unleashedbeast
Ford didn't build it, Tremec did, but I understand what you are getting at. It's very easy. I would suggest putting all 4 corners of the car on jack stands, unless you have access to a lift.
Old 08-09-2010, 06:39 AM
07 GT E UPP
07 GT E UPP's Avatar
Yep, just had mine changed at 60,000 km's (37,300 mi)
and fluid came out slightly on the brownish side. I'm Glad I had it done !!!
I went with Synthetic Royal Purple - Max ATF (3.2 qts).
Took about 45 minutes and my total cost Parts/Labor) was around $100.00
07 GT E UPP is offline
Old 08-09-2010, 06:15 PM
dodger5
dodger5's Avatar
why ATF? i got RP MTF
dodger5 is offline
Old 08-10-2010, 10:34 AM
BigDinTexas
BigDinTexas's Avatar
Why? Because it is alphabetical... "A" comes before "M"...
Actually, the manual says to use ATF IIRC... Probably due to the addititives make it ideal for this particular transmission...
Don
BigDinTexas is offline
Old 08-10-2010, 05:26 PM
dodger5
dodger5's Avatar
Well im done with this job thanks to moosestangs write up on this forum. how do i delete this thread ?
dodger5 is offline
2007StangV6
01-28-2016 06:09 PM
Pyrate Dave
09-10-2015 07:30 PM
IronRaptor
09-09-2015 08:10 AM
Quick Reply: Manual transmission fluid change ?
