Those With New MGW Shifter... what settings do you have? - MustangForums.com
Sponsored by:
Sponsored by:
Old 09-09-2010, 12:22 PM   #1
Blacksmoke
The Paranoid One
Blacksmoke's Avatar
Question Those With New MGW Shifter... what settings do you have?
Installing mine today.
Was wondering what settings most people use.
Was also wondering which settings cause what kind of feel.
Thanks!
Blacksmoke is offline   Reply With Quote
Old 09-10-2010, 09:48 AM   #2
dysan
dysan's Avatar
I've got mine at the recommended 5 turns out from MGW. Nice short shifts and not too notchy.
dysan is offline   Reply With Quote
Old 09-10-2010, 07:25 PM   #3
duckbubbles
duckbubbles's Avatar
I set mine at 7 turns when I installed it 2 years and almost 30,000 miles (wow!) ago. At first I was thinking about shortening it some more but I've left it there and it works good for me. It may be a little notchier that set with fewer turns, but I don't mind.
Frank
duckbubbles is offline   Reply With Quote
Old 09-11-2010, 02:53 AM   #4
Blacksmoke
The Paranoid One
Blacksmoke's Avatar
Mine is at 4 now.
Is it the lower the setting the notchier or the higher?
Old 09-11-2010, 09:29 PM   #5
duckbubbles
As you screw the lower rodend out more turns, you actually create less mechanical advantage as you shorten the throw. This causes increased effort to shift and more notchiness. Design a shifter with throws of 10-12 inches and it will be easy and smooth, but won't fit the character of the car. 4 out turns shifts easier but with a longer throw. 9 turns out will shift harder but have a VERY short throw.
Frank
TNT, New PB TCStangerv6 Street/Strip 12 10-11-2015 05:57 PM
Head swap mustangheaven Classic Mustang General Discussion 2 10-07-2015 10:23 AM
4 Valve Head questions GimpyHSHS 4.6L (1996-2004 Modular) Mustang 6 10-01-2015 09:01 AM
4r70w torque converter q's guitarman376 4.6L (1996-2004 Modular) Mustang 0 09-30-2015 05:54 PM
GT500 front LCA question UrS4 S197 Handling Section 1 09-30-2015 10:13 AM
advantage, ford, gt500, mgw, mustang, newer, setting, settings, shifter, speed, tillman, turns
