Front sway bar end link 08 GT
Old 09-16-2010, 04:27 PM
Mayberry40
Mayberry40's Avatar
Default Front sway bar end link 08 GT
I have done a search and found a lot of info on the trouble with the front end sway bar links on my 08 GT. I can not find anything on how to replace the end links. Is there a link on how to replace them? I would think it would be a fairly simple operation..........but the stealership want $ 150 to replace it....so maybe its not that simple!
Mayberry40 is offline
Old 09-16-2010, 04:32 PM
Unleashedbeast
Unleashedbeast's Avatar
you may have to buy the metal end link rods that already has the threaded bushing installed on them. Replace the entire unit. It doesn't look like the bushing themselves are serviceable.
Unleashedbeast is offline
Old 09-16-2010, 04:33 PM
SpartaPerformance
SpartaPerformance's Avatar
It's extremely simple, you must remember that dealership labor is about $100 - $125 per hour depending on where you live.
SpartaPerformance is offline
Old 09-16-2010, 10:38 PM
tx_zstang
tx_zstang's Avatar
takes 2 wrenches, an 18mm and a 8mm. The 8mm is used to hold the inner stud from turning, using the 18mm to turn the nut.
Same for both bottom and top stud bolts on the links.
tx_zstang is offline
Old 09-17-2010, 08:55 PM
goose5
goose5's Avatar
FYI if you're getting ford links make sure you get nuts too... the new redesign sway bar links have fine thread and the stock ones have coarse thread.
goose5 is offline
Old 09-18-2010, 10:01 AM
157dB
Cut & Paste Expert
157dB's Avatar
Since no one has come up with the link....
Here ya go.
Any more questions?
157dB is offline
Old 09-18-2010, 03:52 PM
Mayberry40
Mayberry40's Avatar
Thanx 157.....that is what I was looking for!
Old 10-07-2010, 09:09 PM
Mayberry40
Mayberry40's Avatar
Does anyone know the replacement part number?
Old 10-09-2010, 09:09 PM
Mayberry40
Mayberry40's Avatar
Anyone
Old 10-11-2010, 09:07 PM
SilverHoss
SilverHoss's Avatar
Updated part numbers:
End Link: BR3Z 5K483 B
Nut: W712503 S440
please note that when I went to order using these numbers, every OEM online parts store I went to , shown no match for the numbers. Or the nut, but not the end-link. So what do you do? Well when you order the OLD end-link, that part is unavailable now, and you get the new part instead !
( I was notified by email that the part I had ordered had been replaced with part # BR3Z 5K483 B - and did I want the updated part? , and I replied Yes, and best i remember, it was less expensive than the old part1 )
SilverHoss is offline
Quick Reply: Front sway bar end link 08 GT
