Issue with the 2005-2007 Mustang 3V Spark plugs?
Old 12-08-2012, 07:18 PM
  #21
SD 197
SD 197's Avatar
This is a great video by Autolite specifically done for the spark plug removal on 4.6 3V.
SD 197 is offline
Old 12-08-2012, 07:19 PM
  #22
SD 197
SD 197's Avatar
How do I delete this extra post?
SD 197 is offline
Old 12-08-2012, 11:56 PM
  #23
Diabolical!
Diabolical!'s Avatar
The blown-out spark plugs is not a problem with the 3Vs. It was a problem with the 2v 4.6, 5.4 and 6.8 (v10) motors. Ironically, the reason we have problems with spark plugs breaking in the 3v motors can partially be attributed to the "fix" for the earlier blow out problems. The threads were moved further up to facilitate more engagement. Unfortunately, this left a long, easily corroded sheild in a tight spot. I've changed quite a few of these using the TSB method and a lot of patience. Been lucky so far and had no breaks. If you use the proper anti-seize on the electrode shield (NOT on the threads), then you won't have any problems at all changing them the next time.
Diabolical! is offline
Old 12-09-2012, 06:59 AM
  #24
moosestang
moosestang's Avatar
Anti-seize is your friend! I wish i had used it on my steel drain plug for my aluminum diff cover!
moosestang is offline
Old 12-09-2012, 07:33 AM
  #25
Norm Peterson
Norm Peterson's Avatar
Anti-sieze is your friend for most any dissimmilar metal threaded connection.
Norm
Norm Peterson is offline
Old 12-09-2012, 11:21 AM
  #26
07BLACKGT
07BLACKGT's Avatar
FWIW I had my dealer do mine @70xxx. Brought the car in that morning to let it cool down, they started and finished it that afternoon. Mechanic was able to remove all 8 without breakage.
07BLACKGT is offline
Old 12-11-2012, 01:48 PM
  #27
gabep06
gabep06's Avatar
If you don't mind me asking, How much did the labor cost you?
gabep06 is offline
Old 12-11-2012, 03:05 PM
  #28
Ford_Dude
Ford_Dude's Avatar
Originally Posted by 68WGT
Good morning gentlemen,
My dad has had an independent garage for 25 years, and I just discussed the 3 valve 4.6 spark plug issue with him. He sees and repairs a lot of spark plug ports on various motors. However, the early 3 valve 4.6 aluminum heads cannot be fixed once the damage is done. The reason is because the hole was drilled in such a way that only 4 or 5 threads hold the spark plug in place. The result is that sometimes, the plugs are blown out because the threads cannot hold them in. Also, if damage is done to the threads, it often times cannot be fixed except by replacing the head. He said in 08 or 09, Ford fixed this problem. He knows much more about the technical details but unfortunately, I just bought a 2007 4.6 L GT before asking him detailed questions about this motor. I pray to god I don't have any problems with this 73k mi vehicle.
I think he's mixing up the 4v heads with the 3v heads and the 5.4 with the 4.6.
No there is no such issue of lack of thread on the 4.6 3v mustang heads.
there is however on f-150's
On 2005 to early 2008 Mustang GT's there are quite a few threads making contact.
Ford_Dude is offline
Old 12-11-2012, 09:32 PM
  #29
07BLACKGT
07BLACKGT's Avatar
Well, the dealer damaged one of my wheels during a tire installation and the wheel is now discontinued. We came to an agreement that they would change my spark plugs to make up for it.
When I did get a quote for new spark plugs, they said they usually replace coil packs at the same time. I forgot how much they said it would be, but it was somewhere between $400-600. I'm sure if you brought them the spark plugs and didn't want coils changed, it would be a lot less.
Old 12-12-2012, 08:49 PM
  #30
Diabolical!
There is absolutely no reason to replace the stock coils if they aren't giving any problems. Your dealer got their money out of that spark plug change...
Quick Reply: Issue with the 2005-2007 Mustang 3V Spark plugs?
