filling up problem
filling up problem
hey so i have a 2006 GT and yesterday when i was at the pump i was having trouble filling up, the nozzle fit in fine but when i tried to give it gas it would keep shutting off like it was full i had to put it in at a really weird angle for it to work. I've heard people have had this similar problem before and was wondering what you guys did to fix it or have any ideas on how to fix it
There's a TSB for that but those that had the work done claimed it didn't always help.
There are some work arounds. Try a different gas station (some pumps are more sensitive than others). Turn the pump nozzle anywhere from 90 to 180 degrees. Slow the delivery as much as possible.
There have been a few rare cases where there was a restriction in some of the tank plumbing.
I have the same issue on both an '05 GT and '07 GT500, so Ford didn't fix it.
Turn the nozzle 180 degrees. It works on 90+% of the pumps I use. Do be aware that occasionally this limits the effectiveness of the overflow valve and so you may spill a little bit of gas.
jessicarabbit
09-25-2015 12:41 PM
09-10-2015 08:39 PM
