car revs on its own, and stalls
OP: What you describe sounds very much like a vacuum leak. The car should be throwing a CEL; if you can download that it would go a long way to letting you know whats going on.
A good indication is if it's throwing the code for "O2 sensor stuck lean" or something similar it is almost certainly a vacuum problem.
The guy above that stated TPS problem may also be on to something as this would also cause a similar situation.
92 5.0stang
08-13-2015 06:46 AM
Milan Dragway
08-12-2015 03:43 PM
