Need Help!! 2007 GT Rotrex Supercharger issue
Thanks for the information. I changed the oil today and Marked the harmonic balancer and the blower pulley. I took it out and once up to 4500 it started again. I matched up the marks on the blower pulley to the belt and the marks on the Balancer to the belt did not match. The marks on the balancer were 90 degrees off from the marks on the belt. I assume that the higher I go in RPM, the more strain on the belt which could cause slippage.
Charlie, Brown, Could the belt slipping cause the trim code errors? I replaced the belt two weeks ago. I am going to pick up a tensioner tomorrow and see what that does.
Thank again for your help.
Neal
Neal
Look for belt dust under the blower pulley, glazing on the belt, listen for belt squeel. Watch your boost gauge. What does it do? Does it stay nice and steady or jump up and down?
Check for unmetered air or leaks in piping between blower and intake.
09-03-2015 07:14 PM
