Possible bad 2nd gear syncro? - Page 2 - MustangForums.com
Sponsored by:
Sponsored by:
Old 04-19-2011, 12:36 PM   #11
TekMan05
TekMan05's Avatar
Well Guys this past weekend I got the stang back to normal running order again. Actually, it's running even better. My friend and I installed a replacement un-used Tremec Transmission this time with Royal Purple Synthetic, A spec Stage 2 clutch, and J&M Rear Lower control arms. The things launches like a raped ape, runs smoother yet firmer and cooler. I'll upload some pics later tonight!
TekMan05 is offline   Reply With Quote
Old 04-26-2011, 11:51 PM   #12
TekMan05
TekMan05's Avatar
Old 04-28-2011, 05:51 PM   #13
daredevil95
daredevil95's Avatar
Good to hear....good luck!! I wouldn't go back to the tranny shop.....ever!
daredevil95 is offline   Reply With Quote
Old 04-04-2014, 12:08 PM   #14
Q8 GooGles
It costs me around 250$ where I live to fix a 2nd gear synchro. I don't understand why it would be so expensive in the US.
I have a bad synchro as well. If I'm running high RPMs on 1st gear and tried shifting it into 2nd it would grind like crazy and has a terribly hard time shifting. I just skip 2nd gear now and shift from 1st to 3rd except if I'm at really low RPMs where the problem wouldn't occur and it would shift normally into 2nd (although not as smooth as before).
EDIT: Congratulations on the new build! I envy you
Q8 GooGles is offline   Reply With Quote
Old 04-08-2014, 06:06 PM   #15
moosestang
what lift is that?
moosestang is offline   Reply With Quote
Blew my rear end :( 67LimeCoupe 5.0L (1979-1995) Mustang 31 09-30-2015 05:46 PM
2014 GT 500 TSB? 04stangman 2005-2014 Mustangs 3 09-26-2015 10:33 AM
Pinion angle, poly bushings, 1 piece DS mtgldr S197 Handling Section 1 09-10-2015 10:43 PM
AODE Woes Pyrate Dave 5.0L (1979-1995) Mustang 8 09-10-2015 08:30 PM
05, 06, 2001, 2011, 2nd, bad, changing, cobra, gear, gt, mustang, start, synchro, syncro, t5
