Noise after Pinion seal replacement
Old 08-31-2015, 01:06 PM
Urambo Tauro
Urambo Tauro's Avatar
I just finished rebuilding my 8.8 with new bearings, etc. Ford's preload specs are as follows:
Pinion bearing preload with used bearings to 0.9-1.6 Nm (8-14 lb-in), and new bearings to 1.8-3.2 Nm (16-28 lb-in.)
Now when I set the preload, I did so with only the pinion gear in place. Now that it's back together, with the carrier and axles installed, I checked to see if there was any change. But with new fluid, and all my bearings being new, I found absolutely no increase in rotational resistance.
If you're not going to replace the bearings, you should be able to get away with just installing a new crush sleeve and setting the preload to the "used" spec. Overtightening the pinion nut renders the old crush sleeve useless.
Urambo Tauro is offline
Old 09-01-2015, 05:16 AM
bstang14
bstang14's Avatar
Default Noise after Pinion seal replacement
Interesting that adding the additional mass did not affect the torque. Good to know.
bstang14 is offline
Old 09-01-2015, 06:05 AM
JCON
JCON's Avatar
Thanks for the info. I replaced the bearings last time. This time will just be a new seal and crush sleeve.
JCON is offline
mtgldr
02-03-2024 09:00 PM
bjdutch2005
03-24-2017 03:38 AM
MusicCity615
09-12-2015 07:05 AM
Emblazoned
09-03-2015 10:45 PM
Quick Reply: Noise after Pinion seal replacement
