lit " 0 miles to empty". How far can I go with that?
I have now lit " 0 miles to empty". How far can I go with that? obviously there is still some liter or two in the tank. Did anybody went there far before it is actually empty ?
Are you broke? Fill the damned tank. Running that low makes you that more likely to...:
- ...be the moron sitting on the side of the road out of gas.
- ...be the moron sitting on the side of the road out of gas that gets hit by another car.
- ...suck the garbage at the bottom of the tank into the fuel system, clogging injectors and fuel filter.
- ...cause damage to your fuel pump since the fuel is also used as a coolant for the exterior of the pump.
my friend has gone like two miles of highway driving like that but he was at 55 and then put it in neutral and coasted...i told him i wouldnt push or walk so good luck with that..still unsure of why you would let it get that low
I was out on a road trip this weekend and found myself 18 miles from town with 33 miles left on the tank. I'd never run that low before.
Just how accurate is that reading folks?
I found a questionable place about 10 miles out and put 10 bucks in the tank to ensure I got home ok.
I've probably gone about 5 miles because I couldn't locate a gas station that was open in the area at that time of night. I still had a decent amount of gas in the tank (pushed the back of the car, heard fuel smacking around in the tank), I'd wager the car could go about 20 miles like that but as stated above, I wouldn't recommend it.
