Bad Vibration and "whir" - Page 3 - MustangForums.com
Sponsored by:
Sponsored by:
Old 07-27-2011, 08:53 PM   #21
Nuke
Nuke's Avatar
Confirm the DS is balanced, the angles are correct, the wheels are properly balanced and be sure the wheel stud clips have been removed on all 4 hubs.
Nuke is offline   Reply With Quote
Old 05-13-2012, 01:09 AM   #22
BigRedRoush
Default Fixed
First of all thank you all for your suggestions and thoughts. Secondly, all issues were fixed. I ended up having the heavy Roush High Performance drive shaft removed and replaced with a custom built aluminum drive shaft. (that solved the vibration. I had a really badly installed set of 3.90 gears removed and replaced with 3.55s for better daily driving gas mileage (although I do miss the launch) and that solved the high whining sound. (and yes the additive is in it)
I will say that it still has a little whine to it, but others have stated the whine never really goes away. And lastly, the shifty feeling from the rear end was caused by a worn out set of BMR lower control arms.
Apparently the people who had this car before it got repossessed and resold where I got it from, had it set up to drag and wore the drive train completely out. But, after some TLC, and about 2000 bucks, she's back to where she needs to be.
I do have another question though. The lower rubber belly pan, apparently came loose finally because the Roush front bumper finally ground down enough that the bolts flew off and caused the belly pan to flip backward and drag down the freeway under the car. It's pretty much destroyed, and I need to know where I can find a new one at, or if I should just start looking at salvage yards.
BigRedRoush is offline   Reply With Quote
S197 Parts baddog671 Parts For Sale 20 07-26-2016 01:20 PM
Bad cylinder? Dathan V6 (1994-2004) Mustangs 4 10-05-2015 05:52 AM
What other parts should I be concerned about if my pinion bearing went bad? KingRando 2005-2014 Mustangs 5 10-02-2015 08:06 AM
I should've known better ChampInSD 5.0L GT S550 Tech 13 10-02-2015 04:55 AM
Rough idle and vibrating 4cylinderplus2 V6 (1994-2004) Mustangs 9 09-30-2015 05:26 PM
2012, 67, 70mph, aluminum, drive, engine, gears, manual, mustang, roush, shaft, shaking, steel, v6, vibration, whirr
