highest milage supercharged/stock motor?
lol why? They're a conjoined company now, and they have the EXACT same issues with their superchargers
I don't think Pro-charger has the same issues though.. they do have a dedicated belt arm tensioner thingy on their kits. Not sure if it makes a difference or not, but they do NOT carry the same warnings and they DO honor their warranty IF failure was under 25 degrees. I spoke with them about this at length, but I suspect the same issues since their housing is also aluminum as is the Vortech/Paxton...
Good luck.. been there, done that. No dice.
If you have winter issues, I'd suggest a twin screw with two sets of pulleys.
5 psi for winter (less boost) and 8 or 10 psi for summer...
I am certain ALL centri's have the same issue, regardless of manufacture. Internally, I do NOT see any differences between them in basic terms.
Lol, I am thinking of just finding a beater car n drive that, cause honestly I don't want to risk it, I just shelled out close to 5 grand for the damn thing, with my luck the v3 will explode first cold start.
At least it doesn't get into the negative digits there (??)
I felt the same way when I discovered the horror about the V3 and winter myself.. I almost went with a winter beater, but decided to just take the damned thing off.
I am a pro at it and can do it with my eyes closed now rofl
I chatted with a fellow on another site that drove his through 2 NY winters. He ended up replacing internal components after the second winter. It made a metallic clanging noise and it through a bearing or something. Not sure if Vortech covered it or not..
