highest milage supercharged/stock motor?
Old 12-09-2011, 01:59 PM
  #41
hammeron
hammeron's Avatar
well you picked a very nice shortblock for the rebuild! i've never heard a single ping from the engine since installing the lower compression short block. every so often i feel like installing the steeda 10 rib kit and upping the boosty, but i soon come back to my senses.
hammeron is offline
Old 12-09-2011, 09:43 PM
  #42
stealth_GT
stealth_GT's Avatar
Originally Posted by al roberts
hammeron
Dyno-tuned at Tasca's. Ran 8psi of boost from 1k miles to 15k miles. dynoed out at 486 flywheel hp, 425 rwhp. Then my wife and I decided that we wanted a little more umph, so we decided on raising the boost to 12 psi. Dynoed out at roughly 550 at flywheel, 475 at rear wheels. Did good for 5k miles. When it blew, it was very quiet. Sounded like a bag of gravel dropped on a cement floor. No big bang like a cast iron block.
I remember that sound. It's engraved in my memory.. forever!
The funny thing is, I could have sworn it was the vacuum hose going to the bypass valve and shutting off all the boost to the motor. Happened all the time on my old 93 Mazda RX-7 twin turbos, infamous for vacuum and coolant line issues due to the heat of the rotary..
little did I know at the time.. was not a hose it was a hole..in the block.. rod.. cracked!
8 psi and 425whp is perfect, especially for an auto.. I would have kept it at that power level,worked with the drive train to get the most power to the wheels rather than upped the boost like that.. 12 psi sounds like a lot..
stealth_GT is offline
Old 12-09-2011, 10:05 PM
  #43
rockinstephen
rockinstephen's Avatar
Hmmm...I never heard of having to remove a supercharger in cold weather. When I lived in Maine I had an "00 Buick Regal GS. I drove it for 3 years and never had a problem. I did change the oil once though...
rockinstephen is offline
Old 12-09-2011, 10:42 PM
  #44
stealth_GT
stealth_GT's Avatar
Roots blower.
Old 12-09-2011, 11:52 PM
  #45
smokievol
smokievol's Avatar
I need to comeback to these threads when I think I need more power.
Seems like the clock is ticking when you go SC with the 4.6
smokievol is offline
Old 12-10-2011, 12:11 AM
  #46
stealth_GT
stealth_GT's Avatar
lol no doubt.. I went boost crazy when I first got my Vortech. High strung boost at that. If it was a roots or twin screw, I think I would have been a lot happier (off the line at least). Even with 10 psi, I ended up wanting 12.. even 15. Not with the stock motor.. no way.. boost is waaay too addicting! lol
When I switch to a TVS, I may end up going with 8 psi and not the 10 I had intended, or possibly even stay as low as 5-6 psi...
firehorse02
11-16-2015 11:28 AM
UrS4
10-03-2015 06:23 AM
Explosive
10-02-2015 07:45 AM
Drastang
09-30-2015 03:48 AM
logan409
09-26-2015 07:43 PM
Quick Reply: highest milage supercharged/stock motor?
