Spark Plug Removal Fail - Page 5 - MustangForums.com
Old 05-02-2012, 02:41 AM   #41
wayne613
wayne613's Avatar
Quote:
Originally Posted by Whitestang41791 View Post
i thought it was the 05-08 2 piece design that was breaking?
Your good. JCON's just a bit frazzled this week with finals, papers due, etc. 2 piece with black boots are the fail-tastic ones. Pre-like 01/08 built stangs. For anyone that has an 08, the "AA" or "AB" code will tell you for certain, which can be found easily on the door sticker. Mine is "AA", meaning I had the 2 piece plug design:
wayne613 is offline   Reply With Quote
Old 05-03-2012, 07:42 PM   #42
Goldenpony
Goldenpony's Avatar
Quote:
Originally Posted by JCON View Post
I almost want to set up a donation link for you as a victim because I know it's true...
Thanks - I think.
Actually, I am the only person I have ever heard of this happening to, but I got a total refund, the entire amount, from Ford Motor Company. I guess it came from the email campaign I went on. I contacted two different offices at Ford as well as the owner of the dealership and a month or two later I was at the service dept for a minor recall and the service manager presented me with the check. I guess I am the squeaky wheel. I am still using Champion #7989 plugs though.
Goldenpony is offline   Reply With Quote
Old 05-04-2012, 12:31 PM   #43
dadirtypoostick
Saw this thread and it makes my lip quiver a bit realizing I have an 05 with 56k on the odometer. hopefully the tool isnt too expensive
dadirtypoostick is offline   Reply With Quote
Old 05-04-2012, 03:56 PM   #44
wayne613
wayne613's Avatar
Quote:
lisle tool on amazon = $60, you can find people re-selling theirs in the for-sale section here after they use it that one time quite frequently for even less. Hell, I don't think I'll ever need to use mine again..So I'll throw that out there, if you want to get it. Never used.
Old 05-04-2012, 10:18 PM   #45
JCON
JCON's Avatar
Quote:
I'd like to attribute that non-use to our mad skillz. Yo.
JCON is offline   Reply With Quote
Old 05-05-2012, 09:39 PM   #46
BAB GT
BAB GT's Avatar
I broke 3 after following all of the recommended steps. The engineer that designed this head/spark plug combination should spend the rest of his days in hell with a Lisle tool up his a@@.
BAB GT is offline   Reply With Quote
Old 05-05-2012, 09:58 PM   #47
pjm435
pjm435's Avatar
before you remove your plugs you should warm up the engine to about 120 deg. then brake them loose 1/4 turn then spray with cleaner. this will help you remove them easier. i deal with at work every day. also put antisieze around the shaft to help with the removal the next time
pjm435 is offline   Reply With Quote
Old 05-05-2012, 10:53 PM   #48
JCON
JCON's Avatar
Quote:
I always put anti-seize on my shaft for easy removal!
Old 05-05-2012, 10:59 PM   #49
wayne613
wayne613's Avatar
TMI man, TMI..
Old 05-11-2012, 05:06 PM   #50
Justinsmt88
I did everything by the books and still six out of the eight snapped off lol that tool is a life saver tho. If I were you i'd get e3 plugs to replace the ****ty ford oem, I have them in my and they are great.
Justinsmt88 is offline   Reply With Quote
HELP! P340 p344 and is not the alternator! Golfsito GT S197 General Discussion 9 10-06-2015 12:02 PM
Low RPM hesitation / misfire between 900-1200 Omgitsa88Stang 5.0L General Discussion 5 10-05-2015 08:33 AM
Diagnosing Fuel Pump & Pressure SteelerNation82 V6 (1994-2004) Mustangs 1 09-16-2015 08:11 AM
Autolite XP Iridium or OEM copper plugs? TfcCDR V6 (1994-2004) Mustangs 0 09-12-2015 05:13 PM
03 V6 Mustang Ticking Noise Emblazoned General Tech 0 09-03-2015 11:45 PM
07, 2000, 2005, 2007, 3, build, carbon, gt, mac, mustang, plug, removal, remove, spark, tool
