Headers with out tune
I am, hopefully, going to buy a set of Kooks LTs. Of course I will have it custom tuned, by Bama, along with all my mods, you can read them in sig. If I have have problems and i return the car to stock tune and take off the CAI, will the car still work properly?
This has to do with warranty, and if I have problems, I want the dealership to only see I have headers. So will the car run? Bama said it wouldn't, but my friend said it would, just really lean.
Returning the air box and tune to stock with the LT's will result in throwing a code since the tune will be looking for the rear O2's. Otherwise, it should run fine.
I assume you will get a set of headers with cats? If so you can return stock tune when air intake is stock and you will be fine with headers. Infact you don't really require a tune for long tubes provided the tune you have now has a good A/F ratio.
I think Sparta is correct when saying the car will probably run just fine, or okay enough to make it there, with the stock tune.
What kind of work at the dealership are you having done?
Luke9222
10-22-2015 11:55 PM
Boostaddict
Lethal Performance
09-08-2015 09:56 PM
09-08-2015 06:25 PM
