Wideband Install Question - MustangForums.com
Sponsored by:
Sponsored by:
Old 01-16-2012, 09:42 PM   #1
Exley
Default Wideband Install Question
Planning on installing a wideband soon. I was curious what bank (driver or passenger) runs leaner?
Exley is offline   Reply With Quote
Old 01-18-2012, 06:09 PM   #2
breathegood
The passenger side should run leaner, as it is farthest from the fuel pump.....in theory.
breathegood is offline   Reply With Quote
Old 01-18-2012, 11:32 PM   #3
tx_zstang
tx_zstang's Avatar
Neither, under part throttle. The PCM will adjust both sides to run them where it want's to.
Under WOT, it's in the tune as to how much fuel gets through the injectors.
tx_zstang is offline   Reply With Quote
Did a few mods this summer... drfister 2005-2014 Mustangs 9 09-04-2015 07:47 AM
HP Gains Without Headers GimpyHSHS 4.6L (1996-2004 Modular) Mustang 7 08-29-2015 06:30 PM
voltage problem? or is it? toastintx64 Classic Mustangs (Tech) 1 08-29-2015 05:12 PM
Dynotech Aluminum Driveshaft Review whatsup62 5.0L GT S550 Tech 0 08-29-2015 01:25 PM
Shaker 500 Dead Battery, Removed Disc Changer Shifty Magoo Audio/Visual Electronics 0 08-25-2015 03:08 PM
0304, 302, 50, band, cobra, dual, ford, forum, install, line, mustang, run, s197, v8, wide, wideband
