cam change vct bolts???
Old 02-09-2012, 12:33 PM
DTMR
DTMR's Avatar
Default cam change vct bolts???
In the PDF it says you need to purchase new vct solenoid bolts from Ford because you cannot re-use them. Ford did not know ecactly what I was talking about and I was wondering why we cannot re-use them. Did anyone else have to change these bolts or know anything about them
DTMR is offline
Old 02-09-2012, 01:33 PM
hammeron
hammeron's Avatar
since you are talking about a cam change, it sounds like you are
asking about what is called cam phaser bolts. the cam phaser bolt
is technically one time use and it holds the cam itself to the phaser
assembly.
hammeron is offline
Old 02-09-2012, 05:59 PM
DTMR
DTMR's Avatar
Okay thats what i was wondering cuz in the pdf it says vct solenoid. Will the comp cams phaser bolts work w the ford hot rod cams?
DTMR is offline
Old 02-10-2012, 09:28 AM
hammeron
hammeron's Avatar
these are the bolts you need (2). if the comp cams bolts
are the same then you are good to go.
http://www.brenspeed.com/3l3z6279da.html
hammeron is offline
Old 02-10-2012, 12:06 PM
Franchi
Franchi's Avatar
It's the same bolt. And yes you need new ones, one time use only.
Franchi is offline
Old 02-12-2012, 11:20 AM
DTMR
DTMR's Avatar
thanks everyone I went with the motor craft ones
DTMR is offline
Tivo304
08-28-2023 12:19 PM
SSG Steggy
3.7L V6 Technical Discussions
11-05-2015 03:09 PM
raleigh05GTO
09-04-2015 07:09 AM
Luke9222
09-04-2015 06:46 AM
Quick Reply: cam change vct bolts???
