Driver's side? My buddy has one on his Boss 302 and has not pulled any oil. He may give it to me after his next track event if he doesn't pull any after that. If he doesn't, I do like the Steeda piece. I assume you re-use the OEM lines.
On the '05-10 you re-use the stock line, and it does go on the driver side on the 4.6L 3V.
Yes the drivers side one that goes into the manifold. I empty it all the time and i pull enough to full the bottom of a paper cup. The higher RPM u drive the more oil you will pull from it because the more suction. So if you are daily driving shifting at like 2-3k rpm then you wont see as much as say if you were doing spirited driving at a higher RPM in second gear through twisty roads. I empty it every 1000 miles and pull enough dirty oil to fill the bottom of a small sized dunkin donuts paper cup. Still better out than in my motor dirtying it up
I daily drive and shift around 2-3k but I also autocross and thats probably when I'll pull some oil. Thanks for all the inputs.
