HELP???
HELP???
Whenever I push the clutch I hear a strange and annoying noise. It doesn't matter if it's in gear or neutral, it's there and it's annoying. Even if I just push the clutch down an inch, I still hear the noise. It sounds like the sound that you hear when you turn the steering wheel all the way. I have 52,000 miles on my car. Can anyone tell me what this noise is? and what I have to do to fix it? Thanks!
Could be the crappy slave cylinder.
it's only rated for 80000 miles, but any kind of aggressive driving it could shorten the life. Mine was completely shredded @ 65K
btw..
TSB=Technical Service Bulletin
IIRC=If I Remember Correctly
FWIW=For What It's Worth (in case you see it)
btw..
Its the bearing, I had the same problem and I needed to change it, you might as well do the clutch too while youre in there
btw..
btw..
