sct data logging abbreviations?
Old 11-08-2012, 02:02 PM
Doug@C&L
Former Sponsor
Doug@C&L's Avatar
Originally Posted by moosestang
Thanks doug! That was very informative. I knew load was calculated using the MAF value, but I didn't know 1.0 was max load for a NA engine or that .15-.20 was normal load at idle. I've seen a max load of 1.6 during WOT in 3rd gear. Can you guesstimate boost based on load?
Not really, simply because every boosted application would be different as it would be air flow dependent. The amount of airflow to make 5 psi on a stock engine would be less then that of a higher flowing engine with different cams or such.
Remember, boost is just the measurement of air flow on a CLOSED intake valve.
Also, centrifugal VS Eaton VS turbocharged would be so very different.
Boost gauge is the best measuring tool, digital is what I like.
Doug@C&L is offline
Old 11-10-2012, 08:28 PM
moosestang
moosestang's Avatar
That makes sense. I have a boost gauge, but it's manual, so I can't incorporate it into my data logs. It would be nice to see boost on the datalog so i could tell if the belt slips.
moosestang is offline
11-18-2015 01:34 PM
piotrek53
10-13-2015 06:54 PM
10-07-2015 07:02 PM
nmra1965
Other Professional Racing
09-26-2015 10:46 AM
03blackwidow
09-20-2015 02:36 PM
Quick Reply: sct data logging abbreviations?
