need help from the power gurus
#44
Updated list:
Exhaust:
Pypes LT headers and O/R shorty x-pipe
Pypes Pype Bomb mid-muffler catback kit
Pypes electric exhaust cutout kit
Suspension:
Eibach Pro-kit lowering springs
Eibach pro-alignment camber adjustment bolts
Koni STR T shocks and struts
BMR rear LCA and relocation brackets
BMR rear adjustable UCA and mount
Eibach front and rear sway bar
J&M adjustable panhard
BMR Subframe Connectors
BMR tubular K-member
i point roll cage
Rear end:
Eaton Detroit Locker differential
FRPP 4.10 gears
Moser 8.8 axles
Swarr bar 8.8" rear support
Drivetrain:
Magnum XL 6 speed transmission
McLeod RXT clutch and flywheel
Aluminum one piece driveshaft
BMR tunnel brace w/ safety loop
Steeda tri-ax shifter
Brakes:
Ford Racing SVT front brake upgrade kit
DBA X-Gold series cross drilled/slotted rear rotors
J&M stainless steel teflon brake lines
SLP line lock kit
Engine:
302 stroker forged short block
CNC ported heads
Comp Cams 127550 FI Stage 2 cams
Valve springs
Phaser limiters
ARP head studs
Kenne Bell Mammoth 2.8 super charger kit
Ford Racing high performance dual fuel pump kit
Ford Racing EV6 high flow 60 lb injectors
Mishimoto performance aluminum radiator
any other suggestions are welcomed!
Exhaust:
Suspension:
i point roll cage
Rear end:
FRPP 4.10 gears
Moser 8.8 axles
Drivetrain:
Brakes:
SLP line lock kit
Engine:
CNC ported heads
Valve springs
Phaser limiters
ARP head studs
KingRando
10-02-2015 08:06 AM
09-25-2015 06:58 PM
