Whats the problem with accel coils?
i noticed smoother acceleration and idle with both accel and msd coils. Of course my stock coils could be weak. If I put a new set of stock coils on, I might notice the same thing. Aftermarket coils also prevent spark blow out on a supercharged car, which means you don't need to gap your plugs so close.
Since you have an 08, you can get the ford racing coils. They are probably made in China though.
http://www.americanmuscle.com/frpp-coilset-0810gt.html
Assuming you have the 12mm spark plugs.
http://www.musclemustangfastfords.co...t/viewall.html
Hey, did you have the accel coils? Why haven't you added a TB at your boost level, you should see a nice gain.
Put the rubber coupler on the TB before you bolt it to the intake. I had to hold the throttle body in my lap and pull the ***** on. I'd hate to have to do it with the TB mounted to the supercharger.
I think i'm going to take it back off and port the whipple intake some. Looking at the openings, they don't look much bigger than the stock throttle body, if any. I should have measured it before I put it all back together.
Went for a drive. The revs come down very slowly, like I lost all my engine braking. That's probably great for road racing, but I don't like it. It never got stuck at 3k at idle or anything weird, but I have to use my brakes now to slow down. I didn't notice any real throttle response improvement, but brenspeeds throttle response was all ready very good.
it did feel like it was accelerating faster. It makes a whistling sound just before the whipple starts whining. If you hold it at just the right pedal position, it sounds like it's ripping a whole in time. I wouldn't have thought it would sound so different.
If the slow return to idle can't be tuned out, then it maybe coming off.
