deep cycling question
Old 02-13-2013, 07:08 AM
DTMR
DTMR's Avatar
Default deep cycling question
If your mustang is not your daily driver and you let it sit for a few days in between driving it, is this considered deep cycling for the battery? If not then what is deep cycling??
DTMR is offline
Old 02-13-2013, 07:58 AM
Ford_Dude
Ford_Dude's Avatar
As I said in the other thread.
Deep Cycling is when you fully drain then fully charge a battery.
doing it rarely isn't to bad, but doing it offten is.
Some with crazy stereo systems get deep cycle batteries because they can drain the batteries fast when the alternator isn't at full speed.
Ford_Dude is offline
Old 02-13-2013, 07:33 PM
Nuke
Nuke's Avatar
Driving your car daily or once every month does not deep cycle your battery. As long as the engine is running, your battery is charging with a healthy alternator. The engine uses the battery for starting only and then it runs off the alternator. In applications like my boat which has a trolling motor, the deep cycle batteries are used all day with a heavy drain from the trolling motor and other electronics with no charging until I get home. Some days I nearly drain them completely. THAT is deep cycling.
Nuke is offline
Old 02-14-2013, 07:41 AM
DTMR
DTMR's Avatar
so you guys dont think what I am doing is deep cycling? Its not me thats killing the red tops?
DTMR is offline
Old 02-14-2013, 10:01 AM
lawrencecar1
lawrencecar1's Avatar
I have a red top. i think it keeps a good charge for about three weeks with no driving. I now keep a trickle charger on it as i dont drive it much during winter months..
lawrencecar1 is offline
Old 02-14-2013, 02:38 PM
Nuke
Nuke's Avatar
If you're killing ANY battery with your car and not trying to power a major metropolis with it, then you need to have the alternator load tested. The charging system on these S197's are barely marginal at best and the alternators are a chronic problem.
Nuke is offline
Old 02-16-2013, 12:05 PM
debit_free_2010
debit_free_2010's Avatar
As the other guys said, Deep cycling a battery is when it's discharged to it's maximum charge loss, usually that's 10.8v. And if it isn't designed as 'deep cycle' battery it will die real quick.
Deep cycle batteries have heavy lead plates designed to hold the charge longer, ie using a trolling motor,
Standard batteries are "dead" at 10.8v, They will loose roughly 5% (more if the battery has some age on it) of its rated capacity each time it's discharged below that.
If you're batteries are dying from sitting for a couple weeks, it's because you have some parasitic drain,
Easy way to check it is wil an amp meter, Standard drain should be less than 50milli-amps.
debit_free_2010 is offline
Old 02-16-2013, 04:42 PM
DTMR
DTMR's Avatar
well i have a accuplus scanner that checks the alternator and diodes and I checked the alternator diodes and it said it was fine still
DTMR is offline
Old 02-16-2013, 05:49 PM
Nuke
Nuke's Avatar
No offense, but from the statements in your original post, I'm not sure how adept you may be at testing the alternator and if an accuplus scanner is the right tool for the job. Take the car to an Autozone or any other auto parts store that'll test it at no charge.
Nuke is offline
Old 02-16-2013, 09:57 PM
mapitts
mapitts's Avatar
^^This^^. I had a 2010 that was a weekend play toy. Kept it for a while until I had to get rid of it for other reasons. Never had a problem with it. it saw about 50 - 100 miles a weekend and a couple of trips to the beach. It would go for about 2 or 3 weeks at a time without cranking. No problems at all. I will also add this for Ford. All Ford's IMHO have barely adequate alternators unless you have a Super Duty.
mapitts is offline
Quick Reply: deep cycling question
