4.10+ gears?
Old 06-21-2013, 09:29 AM
Theron Grant
Theron Grant's Avatar
Originally Posted by stephen1371
It will help but it's up to you really, do you launch your car hard? Do you want to? Can your tires and suspension hold? if not why go 4.10's they really won't help you much if you are doing roll racing, to be honest wont help you at all really
I want to launch really hard just right now when I launch the car bogs way down then starts to move. Its almost like it LAGs out or something I have been told thats because the stock t/q converter has to low of a stall so I am not launching in the power band. I plan to upgrade that soon as well but I have decided to do gears first. When I am racing I run drag radials so I am sure the tires can handle it and I am also looking in to upgrading the suspension so that should be ok to. I guess I am not sure what you mean by roll racing?
Theron Grant is offline
Old 06-21-2013, 09:32 AM
Theron Grant
Originally Posted by outceltj
U need slicks, LCAs, and a torque convertor
For now I am only running the drag radials if they start to slip I guess I will upgrade. I am kinda waiting on the LCAs tell I actually get some tire hop. And torque converter is the next step after gears.
Old 06-21-2013, 09:34 AM
Theron Grant
Sounds like a nice setup up 808muscle glad to see your a Brenspeed fan as well.
Old 06-21-2013, 09:35 AM
Theron Grant
cariacou 2005 - 2010 all have the 5 speed auto 5r55s
Old 06-21-2013, 02:02 PM
stephen1371
stephen1371's Avatar
roll racing is the three honk game people play on the street
stephen1371 is offline
Old 06-22-2013, 07:42 PM
outceltj
outceltj's Avatar
Nice u will love the torque convertor. second best mod ive done
outceltj is offline
Old 06-23-2013, 06:57 AM
mayo
mayo's Avatar
Your kind of caught in the middle, application wise that is. I had a 3.73 with my auto and loved it for a DD, but always felt like a 4.10 would yield better times at the track. Another thing to keep in mind...a/t 1st gear ratio is lower than a manual. The same diff gear will yield more torque with an a/t in other words.
A good combo that I see guys running is a 4.10 gear with a oversized rear tire, like a 305/45/18 DR for the track and a 295/45/18 for the street. The larger tire in the rear will bring the effective gearing down from 4.10 into the 3.90 range. Hope this helps
mayo is offline
Thunderball
15
11-22-2015 11:49 PM
Bokeo
10-10-2015 08:28 PM
KingRando
10-02-2015 08:06 AM
uedlose
The Racers Bench
10-01-2015 08:31 PM
junior04
09-28-2015 10:53 AM
Quick Reply: 4.10+ gears?
