whats better for cams??
Old 07-03-2013, 09:44 AM
DTMR
DTMR's Avatar
Default whats better for cams??
Just graduated college and got some money as a present! I have the FRPP hot rods in my car and I wanted to get either a FRPP manifold or FRPP throttle body for my mustang. I already have the intake and Longtubes so What would give me more of a gain? the manifold or the throttle?
DTMR is offline
Old 07-03-2013, 09:55 AM
hootie_john
hootie_john's Avatar
Neither of those are generally going to be good "bang for the buck" mods. The only benefit to the manifold is that it already has the delete plates in it, but you can get those for ~$300, half the price of the manifold. The manifold doesn't shine until you spin her up pretty tight, which on a stock bottom end, isn't good for engine longevity. The throttle bodies aren't a gain unless you're going big FI (like over 600HP), and generally cause more problems than they are worth.
hootie_john is offline
Old 07-03-2013, 06:11 PM
SpartaPerformance
SpartaPerformance's Avatar
Manifold is a waste. Manifold is for a car that N/A has cams and valvetrain to make power at 7,500RPM. What are your long term goals?
SpartaPerformance is offline
Old 07-04-2013, 12:17 AM
JCON
JCON's Avatar
I would take that money and get rear lower control arms or an aluminum drive shaft. Both will help you go faster!
JCON is offline
Old 07-04-2013, 09:19 AM
DTMR
DTMR's Avatar
well I just got coilovers before so I wanted to do another power mod, and I also want to do the frpp heads (either the stage 1 or the high flow) and eventually do a fully forged bottom end (maybe with a stroker , dont know yet) bump the compression up to 10.1 and if I'm not happy with the N/A setup, throw a blower or turbo on it. (of course this will be an ongoing project). Also, I do like to rev out the motor and would like to keep it witht he ability to rev high, but I keep hearing people go back and fourth with the dexterity of the bottom end. Half the people say that these blocks love to rev, the other say its dangerous. My car pulls super hard all the way to 6800 and I planned on bumping it up to 7k (only if my power is still climbing after heads. Also this is a car that I take drag racing, corner carving, and I want to take it to autocross
DTMR is offline
Old 07-05-2013, 04:51 PM
Ricardo
Ricardo's Avatar
I bet a dyno run will show you a different story on your car pulling hard to 6800. It's most likely just momentum. Been looking at dyno graphs lately and most cars with long tube/FRPP cams as the main mods show HP begin to drop around 6200ish RPM and TQ goes off the cliff around 5500ish RPM. Average TQ around 6500 RPM is 250 lbs. Not much different than a car without these two mods, the dyno graphs look a lot alike, just cams/headers give you bigger numbers before the drop off in power.
I'm no pro but I think you should focus more on getting some useable TQ down low than trying to nickel and dime for the top end. Supercharge it!
Ricardo is offline
Old 07-05-2013, 08:32 PM
clowe1965
clowe1965's Avatar
If you wants to start autocrossing then buying a second set of tires is probably your best bet, you can use them in all racing and keep a set for driving on the road. I've got 285s all around and it makes a huge difference. Plus I can rotate them :-D. Not a power mod but given your budget (assuming less than 1000) you might be able to pick up a cheap set of rims/tires. Looking at your mod list it doesn't look like anything else is left for the engine without replacing either the top or bottom end before you'll gain power. All else fails, save the dough towards your next step.
clowe1965 is offline
Old 07-06-2013, 08:31 AM
JCON
JCON's Avatar
Heads would be awesome but for the price of heads and a stroker kit, you can get a nice high output super charger which will make more than those two combined. Now if your end goal is 700+ rwhp, then start building but just know the FRPP Hot Rods are not a blower cam. Also I know you love revving but as has been stated, why so high? Going an extra 200 RPMs isn't going to give you much of an edge over anyone else be ause of where your power is. Should you decide to push 7,000, you will need new springs and cam phasers and most people go with a lockout. Depending in power, you'll also need to look at new rods and consider new pistons (although a stroke kit I think comes with these). Rods are considered the weak point after 500rwhp but the slightest detonation that high in power can shatter pistons among other parts. I would say you really need to figure out what you want to do with the car and as early as possible. Otherwise you'll know a lot about what's good for different objectives and not have a lot of money because you bought and changed yours frequently.
JCON is offline
Old 07-06-2013, 10:38 AM
Simon1
Simon1's Avatar
A properly tuned FI S197 will rev to 7000 making peak power right at or before 7k.
The heads, cams, intake stuff is cool, but for less money you can make more moneywith a quality blower.
Simon1 is offline
Old 07-06-2013, 06:14 PM
DTMR
DTMR's Avatar
well I dont want to supercharge it until after I build the bottom end, its just not worth it to me to push that power on rods that will blow. I planned on a blower after I do a nice bottom end build which I cannot afford at this point in time, I cant even afford a supercharger right now if I wanted to. I talked with manley about bottom end possibilites and I will go with manley rods/pistons and a kellog crank. I want everything forged. I want to do heads first though. I was looking for a decent mod that would bring in some more power for me right now that wasnt over 650$
DTMR is offline
Quick Reply: whats better for cams??
