Getting Hot
Old 07-22-2013, 02:34 PM
clix813
clix813's Avatar
Default Getting Hot
Ok so I installed some under drive pulleys last week. Ive drove the car a couple of times in between and haven't had any problems. Was driving today and noticed that the coolant light came on and the temp was almost at the red. I pulled over popped the hood and let it cool down. When I got home it I checked the codes to see if it messed anything up and got a p0345 which is cam shaft position sensor. Is this common? I know it was going to run a little warmer just didn't expect it to get insanely hot. Is there ways to fix this like a different thermostat? Thanks
clix813 is offline
Old 07-22-2013, 02:57 PM
clix813
clix813's Avatar
Ok figured it out. Well the heating portion. The fan some how was not plugged in all the way it must not have clicked when I put it on after doing the pulleys. But would the car getting hot or running udp make it show a cam shaft sensor?
clix813 is offline
Old 07-22-2013, 09:36 PM
Lifter583
Lifter583's Avatar
I run a 160 stat in my GT(have UDPs)...but I only drive it in nice weather... never had a heating problem...
Lifter583 is offline
Old 07-22-2013, 10:09 PM
danzcool
danzcool's Avatar
Many times the can shaft sensor will trip when there are alternator issues. It may be that the alternator was borderline failing and the underdrive pulley pushed it over the threshold... I'd just watch for any weird issues and procrastinate for now.
danzcool is offline
Old 07-23-2013, 12:30 PM
moosestang
moosestang's Avatar
Someone else had that code because of udp's.
moosestang is offline
bradleyb
11-27-2015 07:50 PM
88 orangepeel notch
10-05-2015 09:03 AM
jrrhd73must
10-02-2015 09:17 PM
AMAlexLazarus
AmericanMuscle.com
10-01-2015 09:21 AM
bradleyb
California Regional Chapter
10-01-2015 01:02 AM
Quick Reply: Getting Hot
