mustang gt2006 radiator fan problem
Old 08-11-2013, 02:27 AM
alam
alam's Avatar
Well guys i took it to a mechanic today and it seems that the low speed fan is not working but the high speed is working, what might cause that?
alam is offline
Old 08-14-2013, 09:56 AM
ski
ski's Avatar
Possible causes for the fan not running at low speed are a bad relay, burned out resistor, bad/loose electrical connector, or a bad wire.
ski is offline
Old 07-26-2016, 12:33 PM
rgrc27
rgrc27's Avatar
Default I just want to ask if you resolve the problem and how?
Hey I just want to ask you how you fix the problem and what you did to it because I got the same situation on my 2007 gt/cs
Originally Posted by alam
Hey guys, well it happened again few days ago, hitting the fan is not working anymore, but it seems that when i play with the fan relays it works again. I've changed both relays with the horn and rear defroster relays. It Worked for a day and next day the same, the fan won't work until i play with the relays. I noticed that the fan stops working when is car is warm after half an hour driving, suddenly stops and will not work neither with the ac nor with the temperature until i close it and start messing with the relays. I've also noticed that the high fan relay is really hot after turning on the ac for a while..Any thoughts???
rgrc27 is offline
Old 07-27-2016, 02:20 AM
Dino Dino Bambino
Dino Dino Bambino's Avatar
Three years later?
Dino Dino Bambino is offline
Old 07-28-2016, 07:36 PM
jz
jz's Avatar
Three years later?
Not just three years later, but the OPs last activity was Jul 2014. Pretty sure he won't be around to answer.
jz is offline
WDScott
08-17-2015 06:38 AM
Barcafut13
08-13-2015 08:05 AM
daytooday
08-11-2015 09:22 AM
Barcafut13
08-10-2015 07:44 PM
HIS S-197
08-10-2015 05:47 PM
Quick Reply: mustang gt2006 radiator fan problem
