After letting this kit stare at me for almost a year I finally found the time to install it. Everything went smooth, minus some small improvising every thing went together nicely. Seem to be running a lil rich tho at low rpm's is this normal?? Also having some issues with my LT's rubbing the frame and steering column. I hear lower motor mounts will do the trick so I've looked at the modified jdm ones and the upr adjustables, anyone have experience with either??
I am running the Steeda ones, which are also nice. Lowered mine 1/2", but they are adjustable to lower 3/4". I also hear great things about the Prothanes, I think they're what most people go with.
Ok cool I will check those out today trying to fix that rub asap
I have prothanes on mine (standard height) no issues at all. I had JDM dyno tune mine since im in NJ also. I do recommend getting the dyno tune though to dial everything in. Did u gap the plugs tight?
No I actually just put everything in as brenspeed sent it but I do want to get a live tune done as suppose to the generic one the kit comes with I was thinking Tillman for the tune tho how was your experience with jdm and where are they
I did the same thing. I got 3 different boxes lol. My expierence with JDM was awesome. I luv the tune and def will be continuing buisness with them. They r super knowledgable. They r in freehold. www.teamjdm.com What did you gap the plugs at?
