373 vs stock gears - MustangForums.com
Old 11-10-2013, 04:07 PM   #1
kovacsr15
Question 373 vs stock gears
Just bought a 2004 Mustang GT 4.6 , automatic , the motor is fully stock except for the cold air intake. I'm thinking of changing my stock gears to 373/410 would I gain anything? Called a few shops and was told that I was wasting my time , Any thought? I m trying to get faster acceleration w/out hesitation. For now it is not a every day driver I have a warranty on the trans/motor Any suggestions?
kovacsr15 is offline   Reply With Quote
Old 11-10-2013, 04:13 PM   #2
xx10Gt
Quote:
gears make a HUGE difference. If you want pure acceleration, 410s are the way to go. if you want acceleration and still some cruising rpms on the highway go with 373s. Either way its a crazy difference over stock, i dont know why a shop would tell you that.
You dont gain horsepower by the way, it just adds to your accel..
As far as warranty, the shop would have to prove your gears caused the failure for them to have a case.
xx10Gt is offline   Reply With Quote
Old 11-10-2013, 04:33 PM   #3
kovacsr15
thanks for the imput. this is my first Mustang and don't want to blow my bank out
Old 11-10-2013, 04:43 PM   #4
xx10Gt
right... a good gear kit with the install kit AND tuner is about 600. which isnt bad for what youll get. would you install yourself or no?
Old 11-10-2013, 04:44 PM   #5
Nuke
Nuke's Avatar
Wrong forum. You're in the 2005-2014 forum.
A lot depends on what your current "stock" gears are. On the S197's, they could have come with 3.31, 3.55 or 3.73, depending on year, model and options. Not sure about the '04's...
Nuke is offline   Reply With Quote
Old 11-10-2013, 04:52 PM   #6
xx10Gt
i believe 04's came with 3.27s out rear
Old 11-11-2013, 06:39 AM   #7
kovacsr15
Default 2004 mustang
Quote:
thanks for the tip.i am thinking about taking it to lee myles or aamco for the install.do I really need a tune after the install?
Old 11-11-2013, 06:55 AM   #8
xx10Gt
well if you want your speedometer to be correct then yes! any handheld tuner can do it. let us know what gears you decide on.
Old 11-14-2013, 02:38 AM   #9
drewsky
the other section of the forum would help you out a little more im sure. this is 05+ years here. But I do know it will help for sure! No idea why a shop would say it wouldnt.?
drewsky is offline   Reply With Quote
Old 11-21-2013, 03:21 PM   #10
dbspcl
I would be very careful as to whom you take it to, it is a bear to get all the shims in correctly and everything lined up. Also, when you do it make sure you use Royal Purple and/or some friction modifier otherwise you will get noise on slow turns.
I have 4.10's and they are fantastic - love the difference. I have a 5-speed through (1st is now granny gear lol) and I think 3.73's are probably better for your automatic.
dbspcl is offline   Reply With Quote
Switching from 3.89 to 3.00 gears... musnicki Classic Mustang General Discussion 8 09-23-2015 08:11 AM
AODE Woes Pyrate Dave 5.0L (1979-1995) Mustang 8 09-10-2015 08:30 PM
I took delivery on my 2015 GT yesterday Roush05 5.0L GT S550 Tech 11 09-10-2015 01:23 PM
2007 mustang gt vs 2012 mustang v6 Webster454 2005-2014 Mustangs 1 09-07-2015 05:59 AM
