Super charger with frpp intake manifold
Old 11-21-2013, 06:13 PM
gb2010
gb2010's Avatar
Default Super charger with frpp intake manifold
Wanting to get a supercharger for my 2010 and i have a frpp intake manifold. I was looking at the paxton high output but brenspeed says it wont fit with the themostat housing unless i switch the hoses, housing, and crossover to 05/06 style and some people say you can just trim the manifold to fit yet i havent seen anyones pictures that has done it so it seems like they have no clue but are assuming it will work. Next choice is procharger any modifications needed to use that with the ford racing manifold? Any real evidence or pictures would be highly appreciated.
gb2010 is offline
Old 11-22-2013, 05:45 AM
Scott2
Scott2's Avatar
With a 05 - 06 Mustang you can trim the manifold as pictured here:
With a 07 - 10 it is a bit more complicated because Paxton/Vortech provide a spacer that goes between the thermostat housing and block. This spacer has the effect of rotating the thermostat housing neck a few degrees clockwise to allow the thermostat hose to clear the SC pulley.
These show the spacers, thermostat housing and the FRPP Intake sitting on the housing not seating on the cylinder heads.
Here is how I modified my thermostat housing to eliminate the spacer while still clearing the SC pulley.
Thermostat housing marked for cutting.
Thermostat housing cut.
Thermostat housing welded.
FRPP Intake now seats properly.
All done. Mine is a Vortech car but the spacer issue is the same with a Paxton.
Scott2 is offline
Old 11-22-2013, 02:53 PM
Diabolical!
Diabolical!'s Avatar
Well done, Scott. I love those little custom details. I've got quite a few "mods" like that myself.
Diabolical! is offline
Old 11-22-2013, 03:34 PM
gb2010
gb2010's Avatar
Excellent info just what i needed now when you cut the housing did you just turn the piece 180 and weld it or did you give it some more angle? Also how much are you clearing your pulley by now? enough to go bigger if you want?
Any word on a procharger seems like you could just turn the housing to avoid anything in the way i think they can be adjusted. Just weighing my options here.
gb2010 is offline
Old 11-22-2013, 04:07 PM
Scott2
Scott2's Avatar
Thanks! They take time but are certainly worth the effort.
Turned 180 degrees and welded. It still is a close fit. I went from a 3.60" pulley down to a 3.125" pulley for a little more boost in the forged motor with cams and FRPP stage 3 cylinder heads. Complete details on my build are in my garage. Have not measured the actual clearance. The throttle body is very close to the SC, so close I had to remove a UPR polished billet cap on the actuator cover. I am not familiar with ProChargers I can't help you on it.
Scott2 is offline
Old 06-20-2014, 08:59 PM
gb2010
gb2010's Avatar
Just figured id drop an update in here i ended up going with a procharger and there are no issues with the frpp manifold fitment or any special modifications needed other than some cutting of the bumper. Car made 544 hp and 445 tq and has been detuned some for the time being. But now ill soon be installing a paxton on my friends 08 so this thread will come in handy on his install.
gb2010 is offline
Stone629
The Racers Bench
66
06-02-2016 09:52 PM
uedlose
The Racers Bench
10-01-2015 08:31 PM
NYstang
09-30-2015 09:56 PM
Suree_Mustang_2009
09-25-2015 12:58 PM
JDWalton
09-24-2015 08:47 PM
Quick Reply: Super charger with frpp intake manifold
