2008 Mustang GT Voltage Issue
Old 12-20-2013, 05:04 PM
KCKuhns92
KCKuhns92's Avatar
Default 2008 Mustang GT Voltage Issue
My alternator recently went out. I replaced it with a 200 Amp PA Performance alternator. Now that the new alternator is in, the car's voltage fluctuates badly and it runs very rough... Any ideas?
Took it to the shop to have him check it out and he said that the car requires the factory alternator. I have read a ton of people using the 200 Amp PA Performance one just fine.
I'm lost.
KCKuhns92 is offline
Old 12-22-2013, 01:16 AM
flash_xx
flash_xx's Avatar
Did you change the wiring for the new alternator? Stock wires are supposedly too thin for high output alternators, then again I'm running a 220 amp powerbastards alternator with the stock wiring and it works just fine. Maybe you got a bad one.
flash_xx is offline
Old 12-22-2013, 07:35 AM
Nuke
Nuke's Avatar
I'd suspect a faulty voltage regulator which is internal to the alternator. Contact PA Performance or who you bought it from. BUT before that I'd disconnect the wiring and clean the contacts, just to be sure. Many an electrical gremlin have been due to a dirty contact.
Nuke is offline
djbigskrilla
09-20-2022 01:04 AM
mstahoo
SVT Forums
08-19-2021 09:15 PM
jjwinel78
08-17-2015 03:34 PM
daytooday
08-11-2015 09:22 AM
Pain.
08-07-2015 10:48 PM
Quick Reply: 2008 Mustang GT Voltage Issue
