Going for turbocharge 700whp
#31
hi guys, did you used the factory headers and flip it to other side or you've fabricated a custom one ? I noticed that some has used the F150 headers when going for turbo! not sure what is the easy and perfect way to do it.
#32
http://www.cgfabrication.com/shop/ar...53D12.003%2526
#33
You can use the stock headers or any shorty header designed to work with the stock H pipe. I am running the garrett GT4094R 1.09 a/r. I'm just under 600HP at the rear tire on 12 psi of boost and 91 octane. Only 15 degees of timing right now.
Use a 4 inch downpipe, if at all posible with a free flowing exhaust. I am having back pressure issues that I am working on now before I turn the boost up some more.
I used the Mishimoto R Line Intercooler, a very well made 4" intercooler.
Good luck with your build.
#36
I am running the bmr k-member with the 1/2" lower motor mounts and the bmr a-arms. I might switch it out to the race craft setup at some point, but the bmr k-member is a nice piece.
Aliate X
01-22-2005 05:34 PM
