Can I drive the car or wait a tune
Old 04-03-2014, 12:53 PM
m7md88gothica
m7md88gothica's Avatar
Default Can I drive the car or wait a tune
I just installed 373 gear ratio drop and steed a cold air intake
Can I drive normally or slow ? What speed and rpm
Or do I tune it first ? I ordered the sf4 new sct tuner from AM
And they say there might be some kinda wine or something when not installed properly
Now if that happens can it be fixed ?!!!
Thanks guys
m7md88gothica is offline
Old 04-03-2014, 01:28 PM
AJ06GT
AJ06GT's Avatar
Gears are no problem since the only thing the tune does is reset the speedo calibration, but be aware that your speedometer would be wrong until you got your tune.
As for the CAI, if it's a tune required CAI (which I believe all Steeda CAIs are?) it will run lean without a tune. I wouldn't suggest driving it like this. You'll get a check engine light and may cause damage running lean. I'd just wait until you get the tune installed.
Also, I assume you're talking about gear whine when not installed properly. The fix would be to get them installed properly!
AJ06GT is offline
Old 04-03-2014, 01:56 PM
m7md88gothica
I got the engine light on
And I drove slowly maybe till 60 mph but never went more than 3 rpm .
the shop said they installed it properly but am just asking in case if it happens I didn't want to drive fast so I didn't know I mean I won't be able to hear it till I start flooring it am I correct ?
Exactly how will it sounds like ?! I thought I heardd something when I reached around 60 mph but don't know what I still need to drive it properly
Old 04-03-2014, 02:07 PM
redCORTEX
redCORTEX's Avatar
Put the stock intake back on until the SCT x4 gets there.. Don't risk the engine damage.
redCORTEX is offline
Old 04-03-2014, 07:23 PM
tj@steeda's Avatar
Yes, our Cold Air Intakes require tuning.
It is best to put the stock air intake back in until your tune arrives.
Best Regards,
TJ
tj@steeda is offline
Old 04-03-2014, 07:54 PM
Nuke
Nuke's Avatar
Nuke is offline
Old 04-04-2014, 04:45 PM
m7md88gothica
Alright thanks everyone
Old 04-16-2014, 05:14 AM
m7md88gothica
I just got my sct sf4 tuner from American muscle but I didn't get the cables with it
Meh what kind of a cable is it ?
Will it work without it ?!
Old 04-16-2014, 09:32 AM
outceltj
outceltj's Avatar
Wow you should try researching before just installing something and not knowing what the hell your doing. 60mph isn't fast. So it shouldnt cause any damage your freakin hilarious
Do u know how to hook the tuner to your car
outceltj is offline
Old 04-16-2014, 03:24 PM
drewsky
drewsky's Avatar
Also... Your putting a lot of extra miles on your car! Need to calibrate the speedo with the tuner as well as the tube for the Cai. They can do it for you if you don't feel comfortable doing it. But for now put the stock box back on and not to drive too much
drewsky is offline
Quick Reply: Can I drive the car or wait a tune
