Had 4:10 now 3:73 still same problem
Old 05-14-2014, 02:28 PM
Derf00
Gentleman's Relish
Derf00's Avatar
Originally Posted by GurthBrooks
Thanks to everyone who gave their input. I was told that the reason for the vibration and sound is from installing (Ford Racing gears) two separate shops told me this. I was told they are known to be very noisy and have a vibration. Both sets that I have used were Ford Racing 4:10 and now 3:73. Im having a hard time believing that Ford Racing gears could be the reason. Has anyone ever heard of this?
No it's not the ford racing gears causing this. There is an off brand of aftermarket gears that DO have that issue though - Motive gears. The Ford gears are the best ones you can buy for an upgrade on a Ford.
What caused you to replace the Driveshaft two years ago? What did you replace it with OEM or aftermarket? I'd look at the driveshaft first. Take it to a driveline shop, preferably one that builds driveshaft. They'll have the proper equipment to check the trueness and balance of your existing driveshaft and U-joints.
Derf00 is offline
Old 05-14-2014, 03:13 PM
hootie_john
hootie_john's Avatar
Too many people get gears done without issue and don't have vibrations....it ain't the gears unless they were installed wrong. You may get a little whine from them, but not vibration.
hootie_john is offline
Old 05-14-2014, 03:21 PM
TheDivaDanielle
TheDivaDanielle's Avatar
tailshaft?
TheDivaDanielle is offline
Old 05-19-2014, 06:33 AM
2005Redfire6
2005Redfire6's Avatar
Originally Posted by TheDivaDanielle
tailshaft?
That is what it sounds like to me.
It def. isn't the gears causing that unless they were installed blatantly incorrect.
2005Redfire6 is offline
Old 06-21-2014, 09:14 PM
tw1234
tw1234's Avatar
I was told that the reason for the vibration and sound is from installing (Ford Racing gears) two separate shops told me this. I was told they are known to be very noisy and have a vibration. Has anyone ever heard of this?
I had installed FRPP 4.10's into my 05 GT using the proper Ford design Pinion Depth shim gauge and never had one moment of trouble with that gear set. They were quiet but made far too much torque multiplication for the stock tire size. I changed them back to 3.55's after 1.5 years and they still look good as new. I should have bought 3.73's instead.
To the best of my knowledge Ford Racing gears require the proper gear set up tool as they take readings from the shim/bearing side of the pinion to the carrier bearing edge. Most after market gears I've seen have a flat machined surface on the end of the pinion they take their measurement from to the centerline of the carrier bearing. I don't think most shops have the Ford style pinion depth setting tool and just guess by reusing the old shim from the original gears in the vehicle.
http://www.fordracingparts.com/downl...htM-4209-8.pdf
tw1234 is offline
Old 06-22-2014, 01:23 PM
moosestang
moosestang's Avatar
First, try removing your drive shaft from the pinion and turn it 180 degrees, reinstall.
moosestang is offline
Old 06-22-2014, 02:50 PM
GurthBrooks
GurthBrooks's Avatar
Thank you everyone for your help TW1234 had the answer and problem solved. Much nicer ride thanks again everyone!!!
GurthBrooks is offline
articman
06-21-2018 11:45 PM
Seanam
10-04-2015 10:15 AM
stangin1996gt
09-21-2015 11:01 AM
Big Al's 03
Mach 1 Section
09-21-2015 07:59 AM
Ryan Fitzpatrick
09-14-2015 02:21 AM
Quick Reply: Had 4:10 now 3:73 still same problem
