Build Question
Old 05-13-2014, 02:07 PM
P51Dee
P51Dee's Avatar
Default Build Question
OK Guys, I know enough about motors to get myself in serious trouble. Let me start out by saying I wont be able to do anything myself, so I'll need to have this done for me.
I have an 07 GT with only 17,000 miles on it. I want to rebuild the motor with all upgraded performance parts. I'm lookin to get 500-550 horse power (Naturally) out of it.
What do you experienced guys think this would cost me to do? Keep in mind, This was my first Mustang so I want to keep the original motor block. I don't want a supercharger or turbo.....yet. I want to go natural first. What are your thoughts on price?
P51Dee is offline
Old 05-13-2014, 02:46 PM
Mellowdien
Mellowdien's Avatar
550 N/A is most likely impossible.
I'm currently in the process of building mine to 360-370whp N/A.
Full bolt-ons, heads and aggressive cams will get you to 400-420 whp.
I've yet to see anyone ever get close to 500whp out of a 3v, even with a stroked block.
Mellowdien is offline
Old 05-13-2014, 04:21 PM
sactown
sactown's Avatar
Without spray or FI, unless you spend way more money than you should, you won't see those numbers.
sactown is offline
Old 05-13-2014, 05:02 PM
outceltj
outceltj's Avatar
My car is 525 right now. That's with a built motor and a lot of other stuff to go with it. U might as well build a race engine 50k. U need to do some research. How much money do u have. That's the question
outceltj is offline
Old 05-13-2014, 05:38 PM
danzcool
danzcool's Avatar
Not likely to get there NA.
The best bet to get the most power NA would be to go for a 3.7" bore, destroke hte crankshaft, billet rods & pistons, high compression, highley ported heads and big cams, an aftermarket PCM, bigger injectors & fuel pumps, E85 fuel and spin it up to 9000 RPMs. At this point your cost is well into the 10's of K's.
danzcool is offline
Old 05-13-2014, 06:38 PM
jz78817
jz78817's Avatar
the 4.6 3V heads don't breathe well enough to make 500+ hp realistic. you're looking at a crate motor or forced induction.
jz78817 is offline
Old 05-13-2014, 07:55 PM
SpartaPerformance
SpartaPerformance's Avatar
You can 450 with a stroker running 11:1 compression, ported heads, customer cams for that application on all the bolt ons and be streetable but at that cost you might as well through a FRPP Whipple kit on and call it a day and get more power.
SpartaPerformance is offline
Old 05-14-2014, 10:41 PM
drewsky
drewsky's Avatar
Brenspeed builds a nice NA stroker engine! I don't think it's in the 500hp range however.
drewsky is offline
Old 05-15-2014, 10:31 AM
Simon1
Simon1's Avatar
Won't be very street friendly either.
Simon1 is offline
the5
09-19-2015 06:13 PM
2015Ecoboost
09-17-2015 01:48 PM
04stangman
09-17-2015 01:45 PM
rksnow1
09-14-2015 08:46 PM
Quick Reply: Build Question
