Looking for a ARP Balancer Bolt Kit for a 4.6 3V
Old 06-19-2014, 10:07 PM
Mellowdien
Mellowdien's Avatar
Default Looking for a ARP Balancer Bolt Kit for a 4.6 3V
Hey Guys,
I'm doing my cams (comp 127200) in 2 weeks. My mechanic suggested getting an ARP Balancer Bolt Kit and ATI super damper balancer as well.
Found the ATI super damper; http://www.summitracing.com/int/part...9/applications
But i can't seem to find the ARP Balancer Bolt Kit for 3v engines.
I did find this: http://www.summitracing.com/int/parts/arp-156-2501
But it says its for 1992-2004 engines.
Does anyone know where i can find the ARP Balancer Bolt Kit or if i can use the one above on my 3v anyway?
Mellowdien is offline
Old 06-20-2014, 04:03 AM
Simon1
Simon1's Avatar
I would contact ARP.
Simon1 is offline
Old 06-20-2014, 06:37 AM
Scott2
Scott2's Avatar
I used ATI Damper 918039 and ARP bolt 206-1001 (Mini Copper Cam Bolt) in my forged build. It is my understanding 156-2501 is suitable for the OEM damper.
Here is my install process for the damper:
Scott2 is offline
Old 06-21-2014, 12:00 AM
tx_zstang
tx_zstang's Avatar
I use the 2501 arp bolt, but it is a little bit shorter than the stock-length bolt.
tx_zstang is offline
Old 06-21-2014, 01:07 AM
Mellowdien
Mellowdien's Avatar
@Scott2, you're right, i contacted ARP and they did suggest the 156-2501.
Thanks for the pics! i'm sure they'll be helpful when we do the install.
Old 06-21-2014, 06:18 AM
Scott2
Scott2's Avatar
I did not use the 156-2501, I used the 206-1001 because I felt the 156-2501 bolt was too short to use with the ATI Damper. But obviously it worked for tx_zstang.
One other thing to watch for, you will need a T40 Torx Plus bit for use with the 6 counter sunk cap screws. A T40 bit is too small.
Scott2 is offline
Old 06-23-2014, 07:19 AM
Mellowdien
Mellowdien's Avatar
@Scott2, alright thanks, will take a look at the one you used as well.
Already ordered the super damper, what are the benefits of this anyway?
mtgldr
02-03-2024 09:00 PM
maestro1024
09-21-2015 02:40 PM
LivingInThePast
09-16-2015 12:20 PM
angeljoelv
SVT Forums
09-10-2015 09:12 PM
Boostaddict
Lethal Performance
09-08-2015 09:56 PM
Quick Reply: Looking for a ARP Balancer Bolt Kit for a 4.6 3V
