code P115E
Old 08-11-2014, 11:16 AM
bomitchell1974
bomitchell1974's Avatar
Default code P115E
Changed sparkplugs on 2008 ford mustang gt 4.6L and the #1 plug broke . Got it out but very small piece of shaving may have fallen thru. Now service engine light is on . Had code read and its a p115E. Car is running rough. . Seems to be only on passenger side. any suggestions are greatly appreciated.
bomitchell1974 is offline
Old 08-11-2014, 04:09 PM
bl817
bl817's Avatar
what kind of plugs did you swap in? I recall having this same code along with several misfire codes after changing to autolite HT1 and then to E3. put oem motorcraft plugs back in and cleared codes, haven't come back.
bl817 is offline
Old 08-12-2014, 08:35 AM
bomitchell1974
We used the original Motorcraft plugs. The service engine light is coming on sometimes then it goes off and then back on later on. The side where the piece of plug fell sounds horrible .(terrible miss ) and bad smell from tailpipe on that side too.
Thanks for ur help also !!
Old 08-12-2014, 09:57 AM
jpplaw
jpplaw's Avatar
A P115E is a throttle body code. Take it off and give it a good cleaning with Throttle Body cleaner, don't use carb cleaner thoigh.
jpplaw is offline
BOB ROME
07-26-2023 01:54 PM
mrtrodonet
09-19-2020 03:12 PM
lincolnshibuya
12-08-2015 04:37 PM
Dathan
10-05-2015 05:52 AM
ChampInSD
10-02-2015 04:55 AM
Quick Reply: code P115E
