Vacuum hose collapsing
Old 08-08-2014, 08:37 PM
Onyxr33
Onyxr33's Avatar
Default Vacuum hose collapsing
I was doing a check up on my car today and I noticed my vacuum houses running from my catch can are collapsing. I've never seen this happen before should I be worried or do I just need to use a stronger hose
Onyxr33 is offline
Old 08-08-2014, 09:06 PM
edwin108
edwin108's Avatar
Did you use heater hose? You should use fuel/oil rated hoses for your catch can.
edwin108 is offline
Old 08-08-2014, 10:01 PM
Onyxr33
Onyxr33's Avatar
I believe it is heater hose but if not where else should I check
Onyxr33 is offline
Old 08-09-2014, 12:34 AM
tx_zstang
tx_zstang's Avatar
Yeah that's weak heater use. Use a thicker hose!
tx_zstang is offline
Old 08-09-2014, 11:53 AM
dlazrael
dlazrael's Avatar
Advance auto sells the fuel rated / vacuum rated hoses. Just take your car to em and have em come out and measure it and buy it, they sell it by the inch i believe.... Its how I rerouted my PCV for the blower... Though I am considering going to breathers
dlazrael is offline
Old 08-09-2014, 02:05 PM
Onyxr33
Onyxr33's Avatar
I appreciate the help.. I was thinking breathers too but wasn't sure what effects it would have. What's having you consider breathers other then preventing oil from entering the intake
Onyxr33 is offline
Old 08-10-2014, 07:46 AM
2005Redfire6
2005Redfire6's Avatar
Opens up the PCV system and allows the crank case pressure out as well.
2005Redfire6 is offline
Old 08-10-2014, 08:27 PM
Simon1
Simon1's Avatar
Mine does the same thing. It's do for replacement and changing to the correct hose.
If you have a boost gauge it should give you vacuum too. Mines measures around 20-23 in vacuum at idle IIRC.
Simon1 is offline
Old 08-11-2014, 08:14 PM
Onyxr33
Onyxr33's Avatar
thanks fellas I had to travel a bit cause auto zone nor advanced had it but all is well now. Yea Simon it had me nervous for a sec but my gauge reads 23-25 usually
Onyxr33 is offline
Old 08-12-2014, 10:23 AM
Simon1
Simon1's Avatar
I'll look at mine again just to see but that sounds correct.
Simon1 is offline
mrtrodonet
09-19-2020 03:12 PM
baddog671
07-26-2016 01:20 PM
Demodulates
09-18-2015 11:14 AM
LivingInThePast
09-16-2015 12:20 PM
TfcCDR
09-14-2015 12:08 PM
Quick Reply: Vacuum hose collapsing
