Rev's jump to 2K at startup after cleaning T/B.
Old 08-20-2014, 10:07 PM
mojopony
mojopony's Avatar
Question Rev's jump to 2K at startup after cleaning T/B.
My '06GT was idling rough so I removed the throttle body and cleaned it with CRC cleaner. After re-installing the T/B the idle is now smooth & steady, but every time I fire up the car the RPM's jump up to 2,000 and then it settles back down to a normal idle. The rev's have always increased a bit at startup, but never this much. Any advice or input would be greatly appreciated.
mojopony is offline
Old 08-21-2014, 02:53 AM
ticopowell
ticopowell's Avatar
Did you reset the computer when you cleaned the T/B? unhook the battery for a few minutes and turn the lights on to make sure all the power is drained from the system, then hook it back up and see what it does.
ticopowell is offline
Old 08-21-2014, 10:32 AM
waykooljr
waykooljr's Avatar
You should go through the idle relearning process anytime you disconnect the battery, you could even try disconnecting the battery for a bit to try this to see if it helps with your problem.
The process is in your owners manual, on page 204.
Here's a link to the owners manual from Ford, 2006 Ford Mustang Owner's Manuals
waykooljr is offline
Old 08-21-2014, 07:57 PM
mojopony
mojopony's Avatar
Default battery
Thanks guys. I did disconnect the battery overnight, but I didn't follow the re-learning process as specified in the manual. I'll give that a try. Thanks again!
mojopony is offline
Old 08-22-2014, 01:57 AM
drewsky
drewsky's Avatar
The first time I cleaned mine years ago it did this. I started the car and something wasn't right, shut it off immediately and realized I didn't plug the left (driver side) wire harness back!! It revved up just like that for 4-5 days on startup then settled back to normal.. If you disconnect the battery for a while it should solve it right away.. If not don't freak out. It will return to normal, could also be it was really dirty and the computer is adjusting to clean easy opening tb. Just a thought
drewsky is offline
Old 08-23-2014, 10:39 PM
mojopony
mojopony's Avatar
I tried disconnecting the battery again and went through the idle re-learning process per the manual. No change at start-up. I checked the TPS voltage and measured 1.24 volts on my meter. I'm guessing that's around nominal, but I'm not really sure. The culprit must be some quirky thing. I'm not gonna sweat it too much since its not a major issue.
mojopony is offline
Old 08-25-2014, 09:41 AM
Nuke
Nuke's Avatar
Check for air in-leakage before going nutz.
Nuke is offline
Old 08-25-2014, 11:30 AM
dlazrael
dlazrael's Avatar
How exactly do ya check that?
dlazrael is offline
Old 08-26-2014, 10:49 AM
Simon1
Simon1's Avatar
Ever since mine has been tuned it does this. With the first tune it was higher.
Simon1 is offline
Old 08-26-2014, 02:17 PM
Nuke
Nuke's Avatar
Check all of the plumbing ahead of the TB. Any clamp or joint could have slipped or loosened, allowing a gap which allows unmetered air into the engine. There's also occasions where people over-tightened a clamp, deforming the connection.
Nuke is offline
Quick Reply: Rev's jump to 2K at startup after cleaning T/B.
