2005 procharged gt hesitating and loss of
Old 09-25-2014, 08:13 PM
bns941
bns941's Avatar
Default 2005 procharged gt hesitating and loss of
Hi I'm new here and have an 05 mustang with a procharger p1sc and sometimes while taking off it hesitates and has a total lack of power. It doesn't do it all the time but when it does it just hesitates and when I push the gas and nothing happens but then all of a sudden it will take off and run perfect. Cruising down the rd it runs and drives perfect but from a stop the hesitation will sometimes occur. At one point after it happened I shut off the car and when I woke up the next morning I went to start it and nothing would happen. It would crank but not start. So I was clueless... But after awhile of trying to figure it out I decided to change the plugs and after I did that it started right up. But still sometimes had the hesitation issue. I just don't understand why it does that sometimes. Any ideas? I'm kinda pointing towards the throttle body.... But I changed the tpms and throttle body motor and no change. Could it be the entire throttle body? Seems like a lack of fuel. Thanks in advance!
bns941 is offline
Old 09-27-2014, 08:02 AM
Simon1
Simon1's Avatar
I would check all of the intake piping to ensure there no air leak. Go through the entire inlet system and double check it is working correctly.
Have you done work on the car? If so what?
Who tuned it and has it always done it? How long has it done it? Been a weather change?
Simon1 is offline
Old 09-30-2014, 04:35 PM
sactown
sactown's Avatar
This ^^^^ trying cleaning the MAF also
sactown is offline
Old 09-30-2014, 06:38 PM
kzonts
kzonts's Avatar
Mine had a similar issue. It was the traction control. I turn it off unless I'm driving on wet roads now.
kzonts is offline
Old 10-06-2014, 12:24 PM
808muscle
808muscle's Avatar
Have you done any mods to it recently? Stock cops I hope? Aftermarket ones are horrible.
808muscle is offline
baddog671
07-26-2016 01:20 PM
Thunderball
15
11-22-2015 11:49 PM
mdj89
10-08-2015 09:16 PM
Omgitsa88Stang
10-05-2015 07:33 AM
SteelerNation82
09-16-2015 07:11 AM
Quick Reply: 2005 procharged gt hesitating and loss of
