Changing out plugs?
Old 01-29-2015, 12:13 AM
drewsky
drewsky's Avatar
Follow all the steps in the vids you've seen. Don't be afraid to change them just TAKE YOUR TIME. I waited till I had a day off and soaked them over night before hand after I cracked them a 1/4 turn. I spent maybe 6 min on each plug!! Loosen 1/4 turn tighten, loosen 1/2 turn, tighten 1/4 turn and so on... Just be patient or find out the hard way. There are hundreds of horror stories. But if you broke a plug your rushing it plain and simple.
drewsky is offline
Old 01-29-2015, 01:24 PM
bl817
bl817's Avatar
use whatever plugs you want on your 05. headaches will ensue. good luck
bl817 is offline
Old 01-31-2015, 09:14 AM
BrianK
BrianK's Avatar
What headaches are you talking about?
BrianK is offline
Old 02-01-2015, 02:47 PM
bl817
bl817's Avatar
numerous misfire codes leading to failsafe mode. have an extra car on hand to return non oem plugs to parts store. oem motorcraft plugs are gapped .054. Autolites and champions are pregapped .045 and .044 respectively. the '05 is very picky. good luck
bl817 is offline
Old 09-04-2015, 08:27 PM
BrianK
BrianK's Avatar
So - OP - what did you end up doing with your plugs? Any issues?
BrianK is offline
Granatelli Sales
03-25-2016 08:01 PM
2007StangV6
01-28-2016 06:09 PM
Granatelli Sales
12-27-2015 06:28 PM
Emblazoned
09-03-2015 10:45 PM
Quick Reply: Changing out plugs?
