Car randomly dies/odd idle
Old 03-13-2015, 05:36 AM
Spicy_Mchaggiz
Spicy_Mchaggiz's Avatar
Update.
Drove to work, about 10 miles and mostly highway. It seems like it happens much more when I go from 55+ and let it coast before downshifting that it dies. It happened each time when I was above 55 be it coming to an on ramp, getting off, etc. I was lucky enough to watch it and not wreck the damn thing.
Spicy_Mchaggiz is offline
Old 03-13-2015, 08:29 AM
Spicy_Mchaggiz
Performed Idle relearn. No difference.
I've narrowed it down to if I go OVER 50 mph it will bounce rpm's and die.
Old 03-13-2015, 05:57 PM
Nuke
Nuke's Avatar
Can it hold a steady cruising speed without an erratic RPM? How many miles are on the fuel filter?
Nuke is offline
Old 03-13-2015, 08:38 PM
TheDutchTexan
TheDutchTexan's Avatar
It could also be your fuel pump, perhaps it is struggling.
TheDutchTexan is offline
Old 03-14-2015, 08:19 AM
Spicy_Mchaggiz
Fuel filter is 1 month old.
It can hold cruising speed. Though if I let off the gas at speed there is a very noticeable drag to the vehicle.
I have a new throttle body that will be here today or Monday.
Old 03-14-2015, 07:23 PM
Nuke
Nuke's Avatar
A new TB? Oh, joy. More problems...
Nuke is offline
Old 03-14-2015, 09:47 PM
Spicy_Mchaggiz
More problems? How so?
Old 03-14-2015, 10:55 PM
Nuke
Nuke's Avatar
Aftermarket TB's have been known to cause more problems than they cure. They certainly don't add any power unless you're heavily modded or running a strong FI since the stock TB can handle more air than even mildly modded 4.6's need. Whatever you do, hold on to that stock TB.
Nuke is offline
Old 03-15-2015, 06:37 AM
jpplaw
jpplaw's Avatar
Did you clean the MAF sensor like Dino suggested?
jpplaw is offline
Old 03-15-2015, 07:05 PM
Spicy_Mchaggiz
Yup.
You're assuming I went aftermarket. I ordered a ford stock replacement.
I did take the TB off yet again and cleaned it even more and the symptoms are not AS bad, but I do believe this is because the TB electronics are on their way out.
Quick Reply: Car randomly dies/odd idle
