5 speed transmission swap technical problems
Old 04-17-2015, 11:07 AM
Sanchez Auto
Sanchez Auto's Avatar
Default 5 speed transmission swap technical problems
My dad and i swapped a auto trans to a 5 speed trans we changed the necessary like wiring harness the pedals and flywheel but when we went to get it tuned and dynoed there seemed to be a technical problem at the time of tuning we changed the cpu to a 5 speed but it wouldn't start or crank at all the dash would turn on and a wrench tool light would turn on ....so my question is if we missed a cable that needs to be changed or a sensor missing ?? Thanks for the help in advance
Sanchez Auto is offline
Old 04-17-2015, 11:32 AM
bl817
bl817's Avatar
did you have the new 5 speed ecm flashed for the old keys? "PATS" needs addressed IIRC.
bl817 is offline
Old 04-17-2015, 11:36 AM
Sanchez Auto
Yes the tuner guy said he flashed and turned off the cpu and he said that there could be a wrong wiring connection so do you kniw what else i can check first
Old 04-17-2015, 11:38 AM
bl817
bl817's Avatar
clutch pedal switch is about all that comes to mind
bl817 is offline
Old 04-17-2015, 11:42 AM
bl817
bl817's Avatar
im not sure if there is anything in the SJB that needs addressed.
bl817 is offline
Old 04-17-2015, 11:47 AM
Sanchez Auto
Ill check that thanks for the help if theres anything else that could be a problem please comment
Old 04-17-2015, 12:55 PM
bl817
bl817's Avatar
this is kinda old but goes thru the process.
http://www.mustangcollective.com/showthread.php?t=15949
bl817 is offline
Old 04-17-2015, 02:56 PM
Derf00
Gentleman's Relish
Derf00's Avatar
I don't think what the shop did vs what ford does for programming the PCM is the same.
The PCM needs the vin number of a manual car to create the baseline tune file that the car needs. Without it, you can tune it all you want with an aftermarket tuner (or dyno associated tuner) and it won't start. I doubt your shop has the Ford OEM tune files.
Call the dealer and ask about it. I'm pretty certain that's the case, especially since it doesn't sound like you got the PCM out of the donor car.
Derf00 is offline
Old 04-20-2015, 12:49 PM
Sanchez Auto
ohh yes .... we never thought of thanks soo much whenever we go back to the shop we will change that and see what happens thanks again ill let u guys know what happens
Cannibal_carnies
03-02-2023 06:17 PM
KinneyD
01-09-2016 05:33 PM
squishbang
12-04-2015 02:29 PM
Jskeezy84
09-08-2015 01:40 AM
movielover40
08-27-2015 03:26 PM
Quick Reply: 5 speed transmission swap technical problems
