Testing A/F
Testing A/F
My 05 gt is throwing a p2270 code every once in a while, which is bank 1 sensor 2 stuck lean. If i look at my obd2 it shows the the bank 2 sensor 2 is also right there with it. Im wondering if i am runing lean or if it is due to the long tube headers and exhaust setup flowing air easier. I want to see if there Is there a way to test the A/F raito before i go rush to buy a tuner and get a tune to see if that fixes it.
Because long tubes change the position of the front O2's, sometimes it will cause intermittent codes. You are running long tubes without a CAI and tune? That's kind of cart before the horse.You may only need a small tune tweak to change the transfer settings and stop the codes.
A clogged injector would cause a misfire, which you would feel.
Short of an wideband AFR gauge or a sniffer, you can't test the AFR.
Likely that the previous owner boned you by returning it to stock and keeping the tuner, since you said in your first post "before I go rush to buy a tuner and get a tune". So you are running a set up that requires a tune and the seller did the dick move selling the car with the stock tune on it probably so he could keep the tuner for himself.
jwog666
12-27-2021 08:09 PM
AMAlexLazarus
AmericanMuscle.com
10-01-2015 09:21 AM
GT350 S550 Tech
09-29-2015 03:29 PM
