Clutch pedal hard to press when engine is warm
Old 08-03-2016, 09:57 PM
Carlos J Cazares
Carlos J Cazares's Avatar
Or you could copy me and do something slightly different:
http://www.angelfire.com/my/fan/Mustang2006GT/Aero.html
Long tube headers are a perfect heat source for boiling clutch fluid in the lines. They can also heat soak the starter unless you protect it with a heat shield.
Well I ended up looking up online the location and routing of the clutch line and mine is intact in the correct location with the factory heat shield cover as well.
Its not touching the engine or exhaust so maybe... just maybe i have a leak at the exhaust manifold flange or a leaking manifold gasket leak... My exhaust sounds great though with no obvious signs of a leak.
Im also thinking maybe a Cat is beginning to clog and creating hot back pressure.
Or maybe the grease in my Throwout bearing is dried up and producing the heat... the clutch or throwout bearing do make light chatter sounds if the car is parked on a slight upward or downward slop, It goes away when i press the clutch in.
Carlos J Cazares is offline
Old 08-05-2016, 12:37 AM
crjackson2134
crjackson2134's Avatar
So I was planning on having a set of kooks LTH installed on one of my 2014's.
What specifically should be done to totally negate the heat with regards to both the clutch & starter? Or is it even possible?
crjackson2134 is offline
Old 08-05-2016, 12:39 AM
crjackson2134
Sorry, accidently posted in the wrong section. Would this problem also occur on a 2014 5.0 GT?
Old 08-05-2016, 02:54 PM
Dino Dino Bambino
Dino Dino Bambino's Avatar
Not necessarily but who knows? Replacing the stock plastic clutch hydraulic line with a braided steel unit would at least eliminate the risk of the plastic heat fatiguing and sudden loss of clutch pedal pressure. To protect the starter, you could buy a DEI Starter Versa Shield from Summit Racing.
Dino Dino Bambino is offline
Old 08-05-2016, 04:12 PM
crjackson2134
Thanks for the tip. I'll have those on hand when headers go on.
Old 02-23-2020, 02:42 PM
Headbanger2010gt
Headbanger2010gt's Avatar
I was having the same issue in my 2010 5 speed gt premium. I bought a new master cylinder, a remote clutch fluid reservoir and braided line along with a new clutch and flywheel now its like butter. You may also want to look into a billet master cylinder eyelet. Stock is plastic and will break from the stiff pedal
Headbanger2010gt is offline
Old 02-27-2020, 08:18 AM
bl817
bl817's Avatar
Done Dino lol
bl817 is offline
jrylander1
02-13-2016 11:47 AM
pdiddy_86
04-03-2003 11:33 AM
Snufelupogus
03-28-2003 03:13 AM
98StangGT
02-26-2003 12:04 AM
Antdaddy79
02-15-2003 07:58 PM
Quick Reply: Clutch pedal hard to press when engine is warm
